Re: Valve Cover Gaskets W-9 with big springs
[Re: 340Cuda]
#2101096
06/30/16 01:19 PM
06/30/16 01:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does anybody know of a narrow valve cover gasket that can be used with 1.680" O.D springs on a W-9 head that do not need to be trimmed to clear the springs?
Thanks! Bill Lamb I used the MP gaskets(silicone over metal) and had to grind for each spring... I havent heard of any narrow ones EDIT I also had to clearance the reverse lip MP valve covers
[Re: 340Cuda]
#2101119
06/30/16 02:06 PM
06/30/16 02:06 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Cometic makes a w9 valve cover gasket, and all pro makes a valve cover. W9 use the same bolt pattern as stock but they moved the front and rear rail. So if you want it to be correct get those.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 340Cuda]
#2101906
07/01/16 02:58 PM
07/01/16 02:58 PM
MR_P_BODY
Mike,
I was able to find some valve covers that I did not have to clearance, but was trying to avoid chopping the gaskets again.
Brett, Thanks I will look into both of those gaskets, at least they may not need to be trimmed as much.
Bill I never changed gaskets all the years I ran my W-9 so I only cut 1 set EDIT I mod a set of MP cast covers
[Re: 340Cuda]
#2102842
07/03/16 04:06 AM
07/03/16 04:06 AM
1967dartgt
Hilltown Pa
Mike,
Bill They will not need to be trimmed at all, they are the same width as the rail on your head.
[Re: 1967dartgt]
#2103142
07/03/16 05:27 PM
07/03/16 05:27 PM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
They will not need to be trimmed at all, they are the same width as the rail on your head. Brent, Am I correct that Cometic has two gaskets a W-2, W-5, W-7, W-9 model and a W-8 model? I was expecting a W-9 only model and I am not finding it. Thanks, Bill
[Re: W5DART66]
#2103493
07/04/16 11:39 AM
07/04/16 11:39 AM
340Cuda
Tulsa, Oklahoma
C5784-60
This is part number you need for w9 "Cometic Midget & Sprint Valve Cover Gasket" Thanks I never would have found it looking for W-9... Bill
[Re: LA360]
#2104047
07/05/16 01:52 AM
07/05/16 01:52 AM
1967dartgt
Hilltown Pa
How much was the top and rear rails narrowed? I am looking at doing some billet valve covers Get gasket and use that as a template. They changed a lot.
[Re: 1967dartgt]
#2113602
07/19/16 09:40 PM
07/19/16 09:40 PM
Posts: 6,136 Melbourne , Australia
LA360
I found some info on the Cometic gasket site that I will use. I will have to order some gaskets to be sure
Alan Jones
