Re: My 440 was misfiring when idling.
[Re: 451Mopar]
#2100178
06/28/16 09:17 PM
06/28/16 09:17 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
I just went through this. I found a burnt spark plug wire boot. Might not be your problem, but worth checking. I agree... Open the hood at night and look for sparks.. How old are the spark plugs and wires??
[Re: 03dodgeram]
#2100240
06/28/16 10:48 PM
06/28/16 10:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The wires and plugs are one year old. New cap. That means nothing.
[Re: 03dodgeram]
#2100347
06/29/16 01:00 AM
06/29/16 01:00 AM
RapidRobert
pull the plugs & see if any are fouled. If you have any extra plug wires you might sub em in for a quick test. did this start all of a sudden? what did you mean "not at the same time" You might pull the carb top & clean it out and take out the idle mixture screws and blast the ports with a 3 second shot of brake kleen with the thin red straw to get in there. Keep us updated
[Re: 03dodgeram]
#2100684
06/29/16 07:05 PM
06/29/16 07:05 PM
minivan
Eugene, Oregon
Didnt drive the car after i installed the new wires and plugs. Wrong firing order.. Recheck your wires ( Make sure they are on the correct plugs) and then recheck them again......
