Diff bearing ? #209807
01/31/09 08:35 PM
01/31/09 08:35 PM
Ohio
theclutcher Offline OP
Ohio
Have heard of mod to differential bearing in dana application.
For race only they remove every other roller from the cage?
I know there was a term that was used to describe this, having brain fade.
Thanks.
Re: Diff bearing ? [Re: theclutcher] #209808
01/31/09 08:58 PM
01/31/09 08:58 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I wouldn't recommend that.
Are you thinking of the "slick shift" modification for manual transmissions?
Re: Diff bearing ? [Re: theclutcher] #209809
01/31/09 09:02 PM
01/31/09 09:02 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it's called sabotage
Re: Diff bearing ? [Re: jamesc] #209810
01/31/09 09:13 PM
01/31/09 09:13 PM
Ohio
Ohio
it is in fact a mod that has been employed.
Hensley if i recall used to do it amongst others, just cant recall exactly what it entailed.
I was thinking it was called something like pro shifting but for the bearing as it was a removal of every other roller like was done with the transmission cogs.
not for long term, like a pint of diff lube, anything to set the record.
cost $50 to have them done.
Maybe B1Frank would know.
If I find out I will post.
