Track width increase A Body drum to disc #2097335
06/24/16 01:26 PM
06/24/16 01:26 PM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
Could someone please confirm the track with increase going from 70 dart with drum to 73 dart disc set up ?? Thanks
Re: Track width increase A Body drum to disc [Re: RTshaker] #2097378
06/24/16 02:39 PM
06/24/16 02:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes it does increase.
Re: Track width increase A Body drum to disc [Re: RTshaker] #2097402
06/24/16 03:10 PM
06/24/16 03:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You'll be looking at a track increase of approx 1 3/4" (1.750) or 44.45 MM
Dr Diff (moparts member) makes a kit to retain your 70 Dart drum spindles and add the 4 1/2 " Bolt Circle center discs up front...might want to consider that option, unless you want the track increase for larger front tires?
Mike
Re: Track width increase A Body drum to disc [Re: DAYCLONA] #2097416
06/24/16 03:25 PM
06/24/16 03:25 PM
RTshaker Offline OP
RTshaker  Offline OP
yes looking for actual amount ..no don't want the increase and need to stay with the SBP as have new rims and tires
Re: Track width increase A Body drum to disc [Re: RTshaker] #2097841
06/25/16 12:39 PM
06/25/16 12:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you want to stay with small bolt pattern then you can't use a 73 Dart setup because that is large bolt pattern.
Re: Track width increase A Body drum to disc [Re: JohnRR] #2098065
06/25/16 07:13 PM
06/25/16 07:13 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Right, you have to use the 4-piston caliper and small bolt pattern rotor. wave
JB Rhinehart, Realist
A-Body's RULE!
