Indy cast cover studs and bolts #2097011
06/23/16 10:44 PM
06/23/16 10:44 PM
nc
E
earthmover Offline OP
E
nc
What are you guys using on the indy covers for mounting..I have studs and locking bolts but I can't get the socket in at the bottom to tighten them enough to stop leaking..and I'm tired of oil running everywhere even when I jack the front of the car up it leaks out the back..
Re: Indy cast cover studs and bolts [Re: earthmover] #2097044
06/23/16 11:34 PM
06/23/16 11:34 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dude! Sand down the outside of a 1/4" drive socket if you have to. One of the nice things about cast is that you can tighten them down good. I use a 1/4 drive 7/16 deep without any issue.
Re: Indy cast cover studs and bolts [Re: earthmover] #2097074
06/24/16 12:16 AM
06/24/16 12:16 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Use Moroso blue gaskets. And the socket suggested above.
Re: Indy cast cover studs and bolts [Re: earthmover] #2097076
06/24/16 12:22 AM
06/24/16 12:22 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
1/4"- 7/16 deep and I use the thin gaskets and glue them to the bottom of the valve covers.
No issues easy off and on.
Mopar Performance
Re: Indy cast cover studs and bolts [Re: earthmover] #2097079
06/24/16 12:24 AM
06/24/16 12:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run studs, use a 1/4" shallow 7/16 socket, thin (.060") Superformace gaskets. no leaks.
Doug
Re: Indy cast cover studs and bolts [Re: earthmover] #2097370
06/24/16 02:30 PM
06/24/16 02:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
12-point nut.
Re: Indy cast cover studs and bolts [Re: John_Kunkel] #2097496
06/24/16 05:12 PM
06/24/16 05:12 PM
nc
E
E
nc
I run the Superformance gasket the problem is I can't tighten them enough..the 12 point is a good idea I'll try that thanks
Re: Indy cast cover studs and bolts [Re: earthmover] #2097550
06/24/16 07:49 PM
06/24/16 07:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use stainless steel mushroom head cap screws. i have a ball end Tee bar to tighten them down, no leaks from the rocker covers ever from both my Indy headed engine or my Stage 6.
Re: Indy cast cover studs and bolts [Re: earthmover] #2097811
06/25/16 11:49 AM
06/25/16 11:49 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes, the 12 point nuts are a good idea. You can also clearance the valve covers to get a socket in there, I'm sure there is plenty of meat to do it. Modifying a socket is another alternative but they are very hard and difficult to reduce in diameter.
Yes, the gasket performs best when there is proper clamp load applied wink
Re: Indy cast cover studs and bolts [Re: earthmover] #2097842
06/25/16 12:40 PM
06/25/16 12:40 PM
AndyF Offline
AndyF  Offline
When I design valve covers I design in enough clearance for a socket. Not sure why Indy couldn't do the same thing. Only takes 30 seconds to measure a socket and enter the number into the CAD file.
Re: Indy cast cover studs and bolts [Re: earthmover] #2097882
06/25/16 01:52 PM
06/25/16 01:52 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Your covers are awesome. I have the Indy knockoffs from summit and they too are a little tight. I also had to open up the bolt holes because they didn't line up well. Thinking of the hex head cap screw idea for a little extra room.
