Need info on 1990 Chrysler LeBaron #2096933
06/23/16 07:39 PM
06/23/16 07:39 PM
Rocky Hill, Ct
Roadcuda Offline OP
Roadcuda  Offline OP
Rocky Hill, Ct
My sister is looking at a '90 LeBaron convertible she saw at an auto auction place she works at. It has the V6 which I think is the 3.0, an auto trans, and shows approx 44K miles on it. So far I've only seen a picture of it and it appears to be in pretty good shape. What things do I need to look for on it? Specific rust areas, problems with the engine or trans? How about price range, they are asking 2000. Thanks for any ideas you can provide me with.
65 Coronet 500 convertible
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
www.69roadrunner.net www.plymouthbulletin.com
Re: Need info on 1990 Chrysler LeBaron [Re: Roadcuda] #2096951
06/23/16 08:24 PM
06/23/16 08:24 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
If it really has low mileage that helps. The 3.0 Mitsu was known to have valve guides fall down in the head causing oil control issues. Pulled many sets of those heads in the day. If it's a 4spd auto it might be a A604 which were also problematic is the early years.Pulled many of those also.Otherwise that 3.0 was a good runner with plenty of power in those cars and when the 604s worked,they worked well.A good road test is in order...get it good and hot..watch for oil smoke from exhaust and ensure proper trans operation. The 604 had some lip seal issues that failed when hot.
Re: Need info on 1990 Chrysler LeBaron [Re: Roadcuda] #2097130
06/24/16 01:39 AM
06/24/16 01:39 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
We bought our old '95 with 91k and sold it at 172k with likely bad head gaskets (it would run hot on alternating days). We did swap the trans with a 30k miles old factory reman due to front seal leak. It never had trouble shifting. Probably the most reliable used car I've ever bought. Motor mounts are a potential issue for any FWD car and there are no quality aftermarket parts available.
Re: Need info on 1990 Chrysler LeBaron [Re: Roadcuda] #2097133
06/24/16 01:42 AM
06/24/16 01:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd try to look under it at subframe, fuel-brake lines etc. Old enough to be rust bucket.
Re: Need info on 1990 Chrysler LeBaron [Re: Roadcuda] #2097254
06/24/16 11:04 AM
06/24/16 11:04 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Rust areas to watch out for: Floor under drivers feet, rear wheel well lips, especially near the bottom and on the inside, also the bottom inside edge of the doors.
Re: Need info on 1990 Chrysler LeBaron [Re: DaytonaTurbo] #2097261
06/24/16 11:11 AM
06/24/16 11:11 AM
moparx Offline
moparx  Offline
plus all folded over seams on hood,doors and deck lid. rear axle, rear axle/panhard bar mounts, rear spring mounts and strut tower top mounting area. also rocker panels and dog leg area of rear fender openings.
beer
Re: Need info on 1990 Chrysler LeBaron [Re: Roadcuda] #2097409
06/24/16 03:18 PM
06/24/16 03:18 PM
Rocky Hill, Ct
Roadcuda Offline OP
Roadcuda  Offline OP
Rocky Hill, Ct
Thanks for the help gents!
69 Fury convertible
69 Roadrunner
75 Scamp
14 Ram 1500
18 Jeep Cherokee
