Re: Old fuel tank needs cleaning?
[Re: modelmakerinc]
#2095885
06/21/16 09:57 PM
06/21/16 09:57 PM
RapidRobert
I think your pretty much gonna have to pull it cuz there's no real way to get in there to agitate things. if you have a shop that hot tanks blocks that will work tho the EPA is making them harder to come by. Otherwise going to the car wash & using the wand & I would think their soap is pretty stout (maybe maybe not). To ans your Q I think any solvent would suffice. If it is in bad shape I would suggest a new tank, Spectra from Canada is good (I used one & good reports from others also) & it gives you the opportunity to solder in a drain bung and one for the fuel inlet on the front wall near the bottom. You can keep the sending unit as is for that function
[Re: modelmakerinc]
#2096369
06/22/16 06:41 PM
06/22/16 06:41 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I used POR15s kit in my 65s.That was in 98 or so.It was totally nasty and I thought it was junk.Pulled it followed the directions to the letter.Let the sealer set in the tank as instructed drained like it said and thenlet it sit for a day in the sun. Still looks better than new today.Rocky
Chrysler Firepower
