Stuff Happens #2086434
06/05/16 02:43 PM
06/05/16 02:43 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Well with my busy work schedule I don't get much time to work on my 605. I finally got it on the dyno a couple weeks ago and then ran into RF interference problems. Got most of that sorted out and made a couple pulls. After 2 pulls it dropped oil pressure by 20psi. I finally got time to start checking things. I was hoping it had blown out a oil plug on a rocker shaft,or stuck the oil pressure bypass, nope. Pulled the filter and cut it open and found some shiny metal particles in the oil so the pan is going to have to come off. The good news is nothing exited the block or started making real expensive noises. I'm hoping to get it off the dyno and get the pan off sometime this week.Dave
Re: Stuff Happens [Re: quickd100] #2086444
06/05/16 03:06 PM
06/05/16 03:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good luck, hope it's nothing serious.
Re: Stuff Happens [Re: quickd100] #2086486
06/05/16 04:51 PM
06/05/16 04:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You are definitely better off finding it when you still HAVE some oil pressure.
Mopar to the bone!!!
Re: Stuff Happens [Re: quickd100] #2086504
06/05/16 05:21 PM
06/05/16 05:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Hopefully it didnt tear up the crank
wave
Re: Stuff Happens [Re: quickd100] #2086601
06/05/16 08:14 PM
06/05/16 08:14 PM
nielsville, minn.
Q
Q
nielsville, minn.
Well the good part was I hadn't adjusted the oil pressure down yet. It started at 94 psi and had dropped to 74. It's nothing that a proper application of $100 bills can't fix.
Re: Stuff Happens [Re: quickd100] #2095626
06/21/16 01:41 PM
06/21/16 01:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Dave, did you find the cause? confused shruggy
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Stuff Happens [Re: quickd100] #2095681
06/21/16 03:17 PM
06/21/16 03:17 PM
Check the bypass valve in the oil pump cover first twocents It should slide in and out easily, if it is galled up from the metal it won't scopeGood luck, hopefully it is something simple luck
Re: Stuff Happens [Re: quickd100] #2096003
06/22/16 01:14 AM
06/22/16 01:14 AM
nielsville, minn.
Q
Q
nielsville, minn.
Guys, I just finished planting spuds, I haven't had time to even open the garage door. This weekend is my 40th Highschool reunion. I was hoping to drive my wreck to my reunion, that's not going to happen. I've got 2 guys I've got to help sort out their fresh motors the following week. (sometimes life sucks the big one). I'll post my findings when I can get back to it. Dave
