changing to solid cam in the 416 #209561
01/31/09 04:45 PM
01/31/09 04:45 PM
NC
P
phil4161972 Offline OP
P
NC
changing from a hyd. to a solid cam in my 416. do you guys thing there are any changes nessary, other than the obivious, pushrods sprigns etc. seems like i remeber seeing somewhere that you should put the oil crossover thing in the valley if running a solid. any thoughts?
Re: changing to solid cam in the 416 [Re: phil4161972] #209562
01/31/09 04:54 PM
01/31/09 04:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this a street engine? Your going to need adj
rockers also. If its a street/strip type engine you
wont need the cross over
Re: changing to solid cam in the 416 [Re: MR_P_BODY] #209563
01/31/09 05:04 PM
01/31/09 05:04 PM
NC
P
P
NC
its a street strip engine i already have adj rockers. rpm will def stay below 6500.
