changing to solid cam in small block #209554
01/31/09 04:34 PM
01/31/09 04:34 PM
NC
P
phil4161972 Offline OP
P
NC
changing from a hyd. to a solid cam in my 416. do you guys thing there are any changes nessary, other than the obivious, pushrods sprigns etc. seems like i remeber seeing somewhere that you should put the oil crossover thing in the valley if running a solid. any thoughts?
Re: changing to solid cam in small block [Re: phil4161972] #209555
01/31/09 04:44 PM
01/31/09 04:44 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
You do not need to do that.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: changing to solid cam in small block [Re: Rapid340] #209556
01/31/09 04:46 PM
01/31/09 04:46 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
You do not need to do that with a flat tappet cam.
that mod isnt a bad idea but its not necessary. its not a solid vs hyd cam mod. its an oiling mod. i didnt do it on my sb with a solid cam
Re: changing to solid cam in small block [Re: phil4161972] #209557
01/31/09 04:47 PM
01/31/09 04:47 PM
not required. #1 is to check your p/v clearance/coil bind/rocker geometry. Oiling mods will benefit you especially in a higher rpm eng but nothing is required just for the changover.
Re: changing to solid cam in small block [Re: RapidRobert] #209558
01/31/09 04:51 PM
01/31/09 04:51 PM
NC
P
P
NC
thanks for the info. what rpm is considered high enough need the oil crossover?
Re: changing to solid cam in small block [Re: phil4161972] #209559
01/31/09 05:02 PM
01/31/09 05:02 PM
now that you asked here's a link to one of the countries foremost SB oiling experts, It'll take you ~3 hours to absorb/get thru it. go to www.moparchat.com then scroll down to & click on "circle track chat" & it is Sanborns oiling mods that are in a sticky at the top(for good reason). Enjoy! PS his cooling mods are just as advanced & both can be adapted to BB's as well.
Re: changing to solid cam in small block [Re: phil4161972] #209560
01/31/09 05:03 PM
01/31/09 05:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Rocker arms and push rods will be different unless you already have adjustable rockers then only the push rods will be longer with a solid lifter. Springs will be fine unless you are going to a bigger cam. Then use springs rated for the cam being used.
