Page 1 of 3 1 2 3
Front coil over guys. Need some advise #2095289
06/20/16 10:56 PM
06/20/16 10:56 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Ok, so I have made changes to my car. And it doesnt work anymore.
Im wondering what weight spring you guys run in the front of your car. I would like to hear from race car guys at or under 3100lbs
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095334
06/20/16 11:48 PM
06/20/16 11:48 PM
michigan
junior636 Offline
junior636  Offline
michigan
Are you talking about coil overs on stock or an aftermarket rack and pinion set up? The rack and pinion set ups seem to get away with lighter springs due to shock angles and the mounting points of the arms. Coil over conversions on stock stuff would be around a 450lb spring.
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095341
06/20/16 11:54 PM
06/20/16 11:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Still no hook? How much travel do you have now with the coil overs? Calvert likes to see 5" of travel and that seems like it could be difficult with a coil over in the stock shock location.
68 Barracuda Formula S 340
Re: Front coil over guys. Need some advise [Re: Bad340fish] #2095343
06/20/16 11:56 PM
06/20/16 11:56 PM
michigan
junior636 Offline
junior636  Offline
michigan
Shouldn't be, I was building coil over kits for awhile and my kits had dead on 5" of travel at the spindle.
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095350
06/21/16 12:02 AM
06/21/16 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Depending on the front weight... 350 would be close
or 400... put it on a scale
The length also matters
wave
Re: Front coil over guys. Need some advise [Re: junior636] #2095352
06/21/16 12:05 AM
06/21/16 12:05 AM
Most of the coil over and strut front end drag cars with four links or ladder bars cars I've heard of have three inches front travel confused
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095354
06/21/16 12:07 AM
06/21/16 12:07 AM
Charleston
Charleston
Im at 4.75" of drop now. I only had like 3.5 before when the car was working.
I have a 300lb spring in it now and really dont have it compressed at all
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095358
06/21/16 12:11 AM
06/21/16 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Then put a 250 or 275 on it...the front must be light
but you will have to control the lift with good shocks
EDIT
more than likely your looking at a 6" spring in the
250-275 range... that will give you stored energy
and wont let it fall out... but again you will have to
slow it up on extension so you dont get full travel...
if it dont need the travel... but I would rather have to
much than to little
wave
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095368
06/21/16 12:20 AM
06/21/16 12:20 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Seldom is it how MUCH travel, it's usually RATE of travel. This is a moderate HP car, so while it won't need much travel, it will need some stored energy to get things started. So the issue is likely a combination of shock settings and the fact that the car is just sitting on the springs
Re: Front coil over guys. Need some advise [Re: Monte_Smith] #2095381
06/21/16 12:42 AM
06/21/16 12:42 AM
Charleston
Charleston
Monte, thats exactly what Im thinking . I really dont know how to compare a /6 torsion bar to a coil spring
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095383
06/21/16 12:43 AM
06/21/16 12:43 AM
If you push up and down on the front of the car does the front of the car move up and down or is it stiff?
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095393
06/21/16 12:55 AM
06/21/16 12:55 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A torsion bar is a spring, so it has a spring rate............where to find that rate, I don't know. It also depends on how you mounted the shock. The more straight up, the less spring it needs
Re: Front coil over guys. Need some advise [Re: Monte_Smith] #2095403
06/21/16 01:01 AM
06/21/16 01:01 AM
Charleston
Charleston
I guess the way the top mount piece comes out on the angle makes the shock more verticle. The front is very stiff, not like it was with the torsion bars. However, stiffer rebound setting on front shock was helping so I wasnt sure it needed to be loser
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095419
06/21/16 01:29 AM
06/21/16 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You said the shock compresses very little.. you
need lighter springs to get the shock down in farther
but stiffer shock setting... you had 3" before when you
lifted it up.. but now with the 300# your not working
thats because you dont have the 3" anymore.. you have a
lot of non stored energy... get the shock(rod) in farther
but be prepared to stiffen the shock rate to slow it down
wave
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095428
06/21/16 01:57 AM
06/21/16 01:57 AM
Charleston
Charleston
Shock is compressed. Coil is not. I just ordered #250s.
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095431
06/21/16 02:07 AM
06/21/16 02:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is a coil over shock correct... how do you
get the shock compressed and not the coil.. unless
the spring is way too short.. if thats the case like
I said a 6" at 250
wave
Re: Front coil over guys. Need some advise [Re: MR_P_BODY] #2095441
06/21/16 02:47 AM
06/21/16 02:47 AM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
my spring rate is 300 0r 350 and i have 3.75 inch of upword travel
Re: Front coil over guys. Need some advise [Re: MR_P_BODY] #2095523
06/21/16 10:23 AM
06/21/16 10:23 AM
Charleston
Charleston
I said a 6" at 250
wave
When you compress the coil on a coilover shock then the shock extends and vice versa
Re: Front coil over guys. Need some advise [Re: sixpackgut] #2095686
06/21/16 03:27 PM
06/21/16 03:27 PM
I said a 6" at 250
wave
confused When I let my car down on the suspension the coil overs and spring compress, not extend shruggy They extend when I jack the car up and let the suspension hang down on of the coil overs, front or rear work
Re: Front coil over guys. Need some advise [Re: Monte_Smith] #2095721
06/21/16 04:15 PM
06/21/16 04:15 PM
Washington
madscientist Offline
Washington
Seems to me that you can find the torsion bar rates in an old circle track chassis book. I have an old drag chassis book and I will look and see if it's in there.
I know I have seen the rates published.
Page 1 of 3 1 2 3
