Clutch Switch #2094428
06/19/16 02:05 PM
06/19/16 02:05 PM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
What is the best way to bypass clutch/neutral switch on a 70 Super Bee ?
Thank you for your input.
Re: Clutch Switch [Re: jrp16] #2094498
06/19/16 04:14 PM
06/19/16 04:14 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Jumper the terminal on the starter relay to Ground . . . but make sure the trans is in neutral or the clutch is depressed when you crank.
Re: Clutch Switch [Re: 1970_EK2AAR] #2094892
06/20/16 11:53 AM
06/20/16 11:53 AM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Done.... Thank you!
