Grille Textured Argent silver: 70 cuda vs 71 cuda #2087685
06/07/16 12:33 PM
06/07/16 12:33 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I was wondering if the textured argent silver on a 71 cuda grille woulf be the same shade as on a 70 cuda grille?
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2087889
06/07/16 07:13 PM
06/07/16 07:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
bump?
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2088700
06/08/16 11:27 PM
06/08/16 11:27 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I am going to painting my 71 Cuda grille textured argent in the near future. I have chosen to use the Roger Gibson kit which is supplied as 3 different products to be sprayed one on top of the other to get the effect.
I called Roger a couple weeks back because I had some questions on the directions supplied with the kit. I must say he was very helpful as I did learn very much from him including what he has found to be the difference between 70 and 71 texture.
As I said the kit is supplied as 3 different products, all lacquer. The #1 is a highly textured essentially silver/argent paint. The #2 is a clear with some metalflakes mixed in. The #3 is a straight clear which he likes to use to glue the texture down somewhat. What Roger told me for a 71 grille is to just use just #1 and #3. He said a lot of the 70 grilles he has seen have somewhat of a shimmer to them and this is why he includes #2 can.
I did take a little bit of the number #1 from the can and put it on a piece of plastic and compared it to some 71 grilles, headlight rings, and lower grilles I have, some NOS and I will say it matches them very close to almost identical in both color and texture.
Mike Afflerbach
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2088716
06/08/16 11:43 PM
06/08/16 11:43 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks a lot for the reply!!!
I compared an old weathered 71 cuda grille vs another old 70 grille I have and they look to be very similar....still they are really old sun baked grilles, so I cant tell for sure....
But yes, from what I recall I kinda always thought that the 70 grilles were either a bit lighter gray or maybe as you say got a lil bit more shimmer on them.
...But most people just told me both years are the same shade....
I tried the Rattle Can Dark Argent which is supposed to be correct for the 71 and 70 cuda grille and it is defintely not accurate. Texture is a little less coarse, and its also quite darker than my NOS 71 cuda grille I had to compare with.
However, I took the pressurized paints out of the Rattle can and I mixed it with some synthetic enamel silver paint, and also added some ochre and blue IIRC and I was able to lighten it some to make it match to my NOS 71 Cuda grille and I can say I was pretty happy with the results. I will try and post some pics.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2088732
06/09/16 12:01 AM
06/09/16 12:01 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
NOS 71 cuda grillw
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2088736
06/09/16 12:06 AM
06/09/16 12:06 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
My own custom mix using Rattle Can 71 dark argent as a starting point.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2088739
06/09/16 12:07 AM
06/09/16 12:07 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Rattle can Dark Argent
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2089385
06/09/16 11:13 PM
06/09/16 11:13 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Very nice work. I hope mine turns out this well.
Do you know if your NOS grille is an excess production line piece or and over the counter dealer piece? The reason I ask has to do with the black out where the grille textures attach.
I have (4) grilles I'm looking at right now as reference (2) are original to my cars and (2) were replacements bought from dealers. The replacements don't have the blackout while the production line parts do. Also the texture retainers on the replacements are round while the one on the production line pieces are rectangular.
Mike Afflerbach
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2090865
06/12/16 09:31 PM
06/12/16 09:31 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Just gee whiz I used Mopar light argent from year one and found I had to mist it with silver wheel paint, it almost appeared green to me. Here is one center cap already misted over in silver and the other freshly painted in just the argent.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2090867
06/12/16 09:35 PM
06/12/16 09:35 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I also cleared the parts later to preserve them
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2090879
06/12/16 09:58 PM
06/12/16 09:58 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
primer
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2091795
06/14/16 02:19 PM
06/14/16 02:19 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
UCUDANT it looks really nice!!!!! Id say you pretty much nailed it!
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: UCUDANT] #2092048
06/14/16 09:33 PM
06/14/16 09:33 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
could I ask -
how much did you reduce the paint from yearOne?
and did you shake/stir it for a real good bit, before reducing and spraying?
I have used that paint before, and never had it come out with that shade etc...
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2092744
06/15/16 11:36 PM
06/15/16 11:36 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
I had it put in spray cans at a local Napa and I think I shook it good. So I'm not sure what they did to it. It looked OK on the cans lid. Maybe they didn't shaker the can before they worked with it?
You should see my answer to organisol whistling
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2092768
06/16/16 12:13 AM
06/16/16 12:13 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Grille with Roger Gibson paint. I am very happy with the result
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: cudaize] #2092769
06/16/16 12:13 AM
06/16/16 12:13 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Lower grille
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: UCUDANT] #2093886
06/18/16 11:19 AM
06/18/16 11:19 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Okay, I'll bite. What is your answer? Whatever it is it looks pretty good.
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: domingo] #2100846
06/29/16 11:48 PM
06/29/16 11:48 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Thanks it's Planet Colors pcr2
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: UCUDANT] #2102441
07/02/16 11:45 AM
07/02/16 11:45 AM
North Dakota
North Dakota
up For the reply. Now for a problem; I finally found the Planet Color website and the closest textured color I can find is the PCRC18 here.
http://sw-rodandrestocustomcolor.com/colors/PCRC18
What am I missing??
Re: Grille Textured Argent silver: 70 cuda vs 71 cuda [Re: 6PakBee] #2102483
07/02/16 01:54 PM
07/02/16 01:54 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
It might take a call to inquire. That looks very much like it as well. They will tolerate wax BTW unlike the original.
