small block mopar perf water pumps #2093673
06/17/16 07:06 PM
06/17/16 07:06 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Guys,
Are these pumps a good out of the box pump to use on a 2/3 grouted block?
http://www.manciniracing.com/dealpart72.html
the back of the impeller is plated already,
Greg
Re: small block mopar perf water pumps [Re: crash520] #2093733
06/17/16 09:03 PM
06/17/16 09:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I used a stock A/C quality reman unit, cut the disc and installed it my self. Used it on both filled and non-filled blocks. Moroso drive kit, Scirocco radiator with a good fan/shroud unit on it. Never a cooling issue unless we were really hot lapped hard for a few runs on a hot day. I'm sure that one would work fine. An oil cooler would also be helpful on a filled block if the temperature became an issue as the oil is a big part of the cooling, especially on a filled block.
Re: small block mopar perf water pumps [Re: crash520] #2094074
06/18/16 06:01 PM
06/18/16 06:01 PM
Greg save your money, get a parts house rebuilt 8 blader & add the plate yourself. want ~.040" between plate & timing cover flat keeping in mind gasket thickness
Re: small block mopar perf water pumps [Re: crash520] #2094079
06/18/16 06:06 PM
06/18/16 06:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By crash520
Guys,
Greg
REALLY? $605 list for a water pump................... realcrazy
Re: small block mopar perf water pumps [Re: crash520] #2094128
06/18/16 08:04 PM
06/18/16 08:04 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks RR, I can measure up the thickness no problem at all, then just cut out a nice round plate of the appropriate thickness and TIG Tac weld to the ends of each blade right? Mage the diameter a 1/16" smaller than the blade o/a diam Ep make it easier to Tac weld??
Yeah $605 RRetail, really!
Re: small block mopar perf water pumps [Re: crash520] #2094181
06/18/16 10:09 PM
06/18/16 10:09 PM
AndyF Offline
AndyF  Offline
Put a remote pump on it if you can. Cleans up the front of the engine and allows you to pump a lot more water.
Re: small block mopar perf water pumps [Re: AndyF] #2094198
06/18/16 10:50 PM
06/18/16 10:50 PM
yes make the OD of the "tips" a bit less than the OD of the vanes so you can tack weld several of em (maybe all depending on how rigid your plate is) and a hole in the center to weld there. FIRST press the vanes forward against the pump housing to minimize lost flow there also (.030-.040"). There are parting lines in the 1" timing cover short cooling passages on each side & deburr those and deburr the block holes, EVERYTHING to make up for the block fill. EDIT when you press the vanes support the shaft on the other side so it takes the load. MORE EDIT almost forgot, put some feeler gauges between the vanes and the housing when you press it as it will jump on you & undoing that ain't fun
Re: small block mopar perf water pumps [Re: crash520] #2094241
06/18/16 11:48 PM
06/18/16 11:48 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks Rob, Andy, that is a clean engine for sure. However as its mostly a street car Id rather prefer to go mechanical pump over electric to maintain reliability etc. that is a nice set up though for sure.
No prob's Rob, Ive already cleaned up the TC but I'll port match the block as well etc.
Re: small block mopar perf water pumps [Re: crash520] #2094374
06/19/16 11:25 AM
06/19/16 11:25 AM
Az
Crizila Offline
Crizila  Offline
Az
One I did a while ago.
Fastest 300
Re: small block mopar perf water pumps [Re: crash520] #2094379
06/19/16 11:39 AM
06/19/16 11:39 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: small block mopar perf water pumps [Re: crash520] #2094384
06/19/16 11:50 AM
06/19/16 11:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The stock A/C water pump has 8 vanes which will move
more water... then add the plate...some A/C pumps
already have the plate but I dont know which years
wave
Re: small block mopar perf water pumps [Re: crash520] #2094545
06/19/16 05:05 PM
06/19/16 05:05 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
guys, thats awesome, thanks for the help, much appreciated. Out here its law that you must have heated windshield demist so I need to run a pump with the heater inlet so modifying an A/C factory pump works best for me and saves me a couple of $$
