Re: Early b body shocks
[Re: 6T4 Polara]
#2093469
06/17/16 12:42 PM
06/17/16 12:42 PM
RapidRobert
No actual exp but KYB seems to get good reviews here on occaision
[Re: RapidRobert]
#2093491
06/17/16 01:35 PM
06/17/16 01:35 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I put KYB shocks on my '64 Polara and I am using the KYB on the '87 Ram daily driver. Good gas charged shocks and you can get them on www.rockauto.com
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: skicker]
#2093683
06/17/16 08:17 PM
06/17/16 08:17 PM
Posts: 4,715 Wichita
GY3
Wichita
I put Monroes's all the way around on my '63 Dodge. The ride was great! I did replace the fronts only because I wanted 90/10 shock to get the front end up and keep it there for weight transfer. Fronts are now Competition Engineering.
[Re: 6T4 Polara]
#2094221
06/19/16 12:25 AM
06/19/16 12:25 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
On my 63 Sport Fury street/strip car I run the Comp Engineering 90/10's up front and the MP long shocks in the rear to work with the SS springs. Car drives and rides great. Ron
[Re: 383man]
#2094388
06/19/16 12:57 PM
06/19/16 12:57 PM
Posts: 10,559 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used to run Lakewood 90/10's on the front but for my new street car setup I'm running KYB gas units. For the rear I use Rancho adjustable shocks set on 2 for the street and set them on 7 for the track. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
