Re: Grille Textured Argent silver: 70 cuda vs 71 cuda
[Re: domingo]
#2088716
06/08/16 11:43 PM
06/08/16 11:43 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Thanks a lot for the reply!!!
I compared an old weathered 71 cuda grille vs another old 70 grille I have and they look to be very similar....still they are really old sun baked grilles, so I cant tell for sure....
But yes, from what I recall I kinda always thought that the 70 grilles were either a bit lighter gray or maybe as you say got a lil bit more shimmer on them.
...But most people just told me both years are the same shade....
I tried the Rattle Can Dark Argent which is supposed to be correct for the 71 and 70 cuda grille and it is defintely not accurate. Texture is a little less coarse, and its also quite darker than my NOS 71 cuda grille I had to compare with.
However, I took the pressurized paints out of the Rattle can and I mixed it with some synthetic enamel silver paint, and also added some ochre and blue IIRC and I was able to lighten it some to make it match to my NOS 71 Cuda grille and I can say I was pretty happy with the results. I will try and post some pics.
[Re: domingo]
#2088736
06/09/16 12:06 AM
06/09/16 12:06 AM
domingo
EL Master
EL Master
Lima, Peru
My own custom mix using Rattle Can 71 dark argent as a starting point.
[Re: domingo]
#2088739
06/09/16 12:07 AM
06/09/16 12:07 AM
domingo
EL Master
EL Master
Lima, Peru
Rattle can Dark Argent
[Re: domingo]
#2090865
06/12/16 09:31 PM
06/12/16 09:31 PM
Posts: 8,149 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Just gee whiz I used Mopar light argent from year one and found I had to mist it with silver wheel paint, it almost appeared green to me. Here is one center cap already misted over in silver and the other freshly painted in just the argent.
[Re: UCUDANT]
#2092048
06/14/16 09:33 PM
06/14/16 09:33 PM
Posts: 238 Florida, US
72ls5fla
Florida, US
Just gee whiz I used Mopar light argent from year one and found I had to mist it with silver wheel paint, it almost appeared green to me. Here is one center cap already misted over in silver and the other freshly painted in just the argent. could I ask - how much did you reduce the paint from yearOne? and did you shake/stir it for a real good bit, before reducing and spraying? I have used that paint before, and never had it come out with that shade etc... Bill
Got me a NEW Project 1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior. Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
[Re: cudaize]
#2092769
06/16/16 12:13 AM
06/16/16 12:13 AM
Posts: 638 SE PA
cudaize
SE PA
[Re: UCUDANT]
#2093886
06/18/16 11:19 AM
06/18/16 11:19 AM
Posts: 10,759 North Dakota
6PakBee
North Dakota
I had it put in spray cans at a local Napa and I think I shook it good. So I'm not sure what they did to it. It looked OK on the cans lid. Maybe they didn't shaker the can before they worked with it? You should see my answer to organisol Okay, I'll bite. What is your answer? Whatever it is it looks pretty good.
[Re: UCUDANT]
#2102441
07/02/16 11:45 AM
07/02/16 11:45 AM
6PakBee
North Dakota
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) For the reply. Now for a problem; I finally found the Planet Color website and the closest textured color I can find is the PCRC18 here. http://sw-rodandrestocustomcolor.com/colors/PCRC18 What am I missing??
