Having issues with fuel level gauge. Truck is an 1985 W150. gauge reads full all the time. pulled sender, cleaned, checked float. used ohm meter to check resistance in full and empty positions, all checked good. Changed gauge out with known good gauge from another truck. stumped......
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205 2002 3500 extended cab, 4x4, Cummins and 6 speed 1997 Ram 2500 5.9 with 35 Boggers - Mud Racer 1993 Dakota 4x4, Dana 60's front and rear - work in progress 1992 Dakota 2wd short bed, awaiting 440 swap
