Re: Vibration enigma any ideas?
[Re: keith airgrabber]
#2090193
06/11/16 04:07 PM
06/11/16 04:07 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Are you sure that you have a matching clutch plate. That is balanced for an internal balanced 440 you have a internal balanced engine 440, and not a cast shaft/external balanced plate
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
#2090200
06/11/16 04:15 PM
06/11/16 04:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You might be surprised, and I've seen it before, engine seems to idle well, no obvious misfire, but there may be a wire crossed, CONFIRM the FIRING order, rotor location #1 under the cap, check the plug wire orientation
I purchased a vehicle from an ASE certified shop where the techs toiled for weeks trying to solve the "vibration" issues on a Dodge Ram,...after buying it I spent 5 minutes and found that the wires on two cylinders were misplaced on the firing order, this after the ASE techs replaced everything under the sun and were preparing to tear apart the drivetrain before deciding to take me up on my offer to buy it...sometimes it's the simplest things we over look
[Re: MoparforLife]
#2090219
06/11/16 05:03 PM
06/11/16 05:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Are you sure that you have a matching clutch plate. That is balanced for an internal balanced 440 you have a internal balanced engine 440, and not a cast shaft/external balanced plate Matching clutch plate? Not sure what you are thinking of, but the only thing different between and internal and external balanced 440 is the flywheel, the rest of it is the same.
#2090220
06/11/16 05:04 PM
06/11/16 05:04 PM
RapidRobert
About a week ago he found a bent pushrod. Replaced it thinking it would be the problem. It still vibrates bad. do a compression test to see if there ain't a dead hole. Started out of the clear blue? any parts changes/adjustments immediately preceding the onset? internally balanced? as no weights that coulda fallen off (a stretch but wanna cover everything that comes to mind). Yes check that firing order (esp 5/7). I have a similar story but it is tragic so I will pass. I would never suggest purchasing parts blindly (shotgunning) to try to solve an issue but would you have another ECU and coil you could sub in (one at a time) to elim them. keep us posted
[Re: Supercuda]
#2090324
06/11/16 10:18 PM
06/11/16 10:18 PM
MoparforLife
Upper Midwest
meant flywheel. Sorry. Mind ahead of fingers.
#2090457
06/12/16 03:17 AM
06/12/16 03:17 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Car has a new pressure plate and clutch. compression test was done and was fine. pulley balancer was swapped out , different fan. All did not help. Maybe It is the flywheel. It may have not been cut before new pressure plate and disk were installed. Vibration is felt in neutral. This I think would make sense. I will have ask my Dad if he had it cut/balanced ? if it's felt in neutral and car is not moving it's an imbalance issue ... or 5 and 7 swapped ... You never said , what year the engine is ? and what do you mean by "pulley balancer was swapped out" ?
#2090608
06/12/16 01:11 PM
06/12/16 01:11 PM
JohnRR
It's the correct weighted balancer I assume ? There are 3 different weighted balncers for big blocks , the one for the 383/400 is closer to the 6pk balancer than the cast crank balancer is.
Also it needs a weighted flywheel , is it the correct one ?
#2090657
06/12/16 02:49 PM
06/12/16 02:49 PM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
A 1970 440 HP engine most likely has the huge six pack connecting rods requiring the six pack harmonic balancer. Does your balancer have the offset weight built into it on the front or a neutral balancer? If you have the neutral balancer you need the six pack one.
#2093188
06/16/16 09:23 PM
06/16/16 09:23 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Rebuild time.Time to put the 426 street wedge back in her I guess. Go ahead. Throw money away. Verify the flywheel balance first.
#2099274
06/27/16 02:16 PM
06/27/16 02:16 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
I chased a vibration for a while in one of my cars. Did the usual. Replaced motor mounts, trans mount, U joints, balanced wheels & tires and even tried a different set of wheels & tires for a while. It turned out to be the crank damper. It was all dry rotted. When I took it off & replaced it with a new Pioneer damper all of the vibration went away. Then I noticed while sitting up on my shelf for several weeks the old damper had actually separated into two pieces while sitting so yeah, it was due to be replaced.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
