Vibration enigma any ideas? #2090190
06/11/16 03:59 PM
06/11/16 03:59 PM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
My Dad has a 65 coronet with a 440 and 4-speed. he has a vibration that almost feels like a missfire. He literally replaced and checked everything dropped oil pan no metal shavings did the clutch new u joints. all electrical etc. About a week ago he found a bent pushrod. Replaced it thinking it would be the problem. It still vibrates bad. Heres the thing it can be felt in neutral when reving the engine . Comes on at like 1500 rpm I think he said. Any ideas would be appreciated. He is at wits end. I would have thought it could be a bad ecu or distributer. He replaced it all.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090193
06/11/16 04:07 PM
06/11/16 04:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Are you sure that you have a matching clutch plate. That is balanced for an internal balanced 440 you have a internal balanced engine 440, and not a cast shaft/external balanced plate
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090200
06/11/16 04:15 PM
06/11/16 04:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You might be surprised, and I've seen it before, engine seems to idle well, no obvious misfire, but there may be a wire crossed, CONFIRM the FIRING order, rotor location #1 under the cap, check the plug wire orientation
I purchased a vehicle from an ASE certified shop where the techs toiled for weeks trying to solve the "vibration" issues on a Dodge Ram,...after buying it I spent 5 minutes and found that the wires on two cylinders were misplaced on the firing order, this after the ASE techs replaced everything under the sun and were preparing to tear apart the drivetrain before deciding to take me up on my offer to buy it...sometimes it's the simplest things we over look
Re: Vibration enigma any ideas? [Re: MoparforLife] #2090219
06/11/16 05:03 PM
06/11/16 05:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Matching clutch plate? Not sure what you are thinking of, but the only thing different between and internal and external balanced 440 is the flywheel, the rest of it is the same.
Don't be the exception.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090220
06/11/16 05:04 PM
06/11/16 05:04 PM
do a compression test to see if there ain't a dead hole. Started out of the clear blue? any parts changes/adjustments immediately preceding the onset? internally balanced? as no weights that coulda fallen off (a stretch but wanna cover everything that comes to mind). Yes check that firing order (esp 5/7). I have a similar story but it is tragic so I will pass. I would never suggest purchasing parts blindly (shotgunning) to try to solve an issue but would you have another ECU and coil you could sub in (one at a time) to elim them. keep us posted
Re: Vibration enigma any ideas? [Re: Supercuda] #2090324
06/11/16 10:18 PM
06/11/16 10:18 PM
Upper Midwest
Upper Midwest
meant flywheel. Sorry. Mind ahead of fingers.
Re: Vibration enigma any ideas? [Re: MoparforLife] #2090442
06/12/16 02:38 AM
06/12/16 02:38 AM
K
K
Car has a new pressure plate and clutch. compression test was done and was fine. pulley balancer was swapped out , different fan. All did not help. Maybe It is the flywheel. It may have not been cut before new pressure plate and disk were installed. Vibration is felt in neutral. This I think would make sense. I will have ask my Dad if he had it cut/balanced ?
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090457
06/12/16 03:17 AM
06/12/16 03:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if it's felt in neutral and car is not moving it's an imbalance issue ... or 5 and 7 swapped ...
You never said , what year the engine is ?
and what do you mean by "pulley balancer was swapped out" ?
Re: Vibration enigma any ideas? [Re: JohnRR] #2090566
06/12/16 12:06 PM
06/12/16 12:06 PM
K
K
The engine is a 1970 HP 440 out of a cuda that was put in around 1973 purchased for 90 dollars replacing a 426 street wedge. So the motor is a forged crank .Balancer pulley. I meant harmonic balancer or damper was replaced with another just to rule it out.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090608
06/12/16 01:11 PM
06/12/16 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's the correct weighted balancer I assume ? There are 3 different weighted balncers for big blocks , the one for the 383/400 is closer to the 6pk balancer than the cast crank balancer is.
Also it needs a weighted flywheel , is it the correct one ?
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090657
06/12/16 02:49 PM
06/12/16 02:49 PM
God's Country Maryland
GODSCOUNTRY340 Offline
A 1970 440 HP engine most likely has the huge six pack connecting rods requiring the six pack harmonic balancer. Does your balancer have the offset weight built into it on the front or a neutral balancer? If you have the neutral balancer you need the six pack one.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2090857
06/12/16 09:22 PM
06/12/16 09:22 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Does it have an engine driven fan? Run it with no belts.
Re: Vibration enigma any ideas? [Re: Magnum] #2092803
06/16/16 01:18 AM
06/16/16 01:18 AM
K
K
Was run without belts and #5 and 7 plugs are correctly routed. ?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2092805
06/16/16 01:20 AM
06/16/16 01:20 AM
K
K
Rebuild time.Time to put the 426 street wedge back in her I guess.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2093188
06/16/16 09:23 PM
06/16/16 09:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Go ahead. Throw money away.
Verify the flywheel balance first.
- Stu Harmon
Re: Vibration enigma any ideas? [Re: JohnRR] #2098344
06/26/16 04:54 AM
06/26/16 04:54 AM
K
K
Vibration is fixed . It was the rubber transmission mount was worn. Fixed everything.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2098407
06/26/16 11:12 AM
06/26/16 11:12 AM
I never woulda guessed that it was that.
Re: Vibration enigma any ideas? [Re: RapidRobert] #2099046
06/27/16 02:13 AM
06/27/16 02:13 AM
K
K
Yeah I know rite. My Dad went through everything and read online that the trans mount can cause alot of vibrations. It was the ticket. He is very happy and has already been out to a cruise night again.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2099274
06/27/16 02:16 PM
06/27/16 02:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I chased a vibration for a while in one of my cars. Did the usual. Replaced motor mounts, trans mount, U joints, balanced wheels & tires and even tried a different set of wheels & tires for a while. It turned out to be the crank damper. It was all dry rotted. When I took it off & replaced it with a new Pioneer damper all of the vibration went away. Then I noticed while sitting up on my shelf for several weeks the old damper had actually separated into two pieces while sitting so yeah, it was due to be replaced.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Vibration enigma any ideas? [Re: keith airgrabber] #2099281
06/27/16 02:29 PM
06/27/16 02:29 PM
fury4speed Offline
fury4speed  Offline
I had a vibration also in my engine , I replaced a lot of parts but in the end it was a bad harmonic balancer. This place rebuilds balancers.
http://www.damperdoctor.com/
