Re: Small Block Chrysler dowel hole rod bearings.
[Re: Bighead440]
#2073915
05/15/16 04:33 PM
05/15/16 04:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looking for some doweled SB MoPar rod bearings, and need a source. I had seen C&A bearings in the past but that seems to be a dead end now. I know that ordinary bearings can be drilled, but who has a fixture and would drill the holes for me? I hope to assemble a 3.79" stroke 340 based engine with 6.25" MoPar aluminum rods soon, and they have the dowels in them as usual with alloy rods. Thanks in advance! RB I might have the drilling fixture still around.. I used a old rod and drilled holes through it to do the bearings.. I will look tomorrow... IF I still have it you can have it ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Bighead440]
#2073924
05/15/16 04:39 PM
05/15/16 04:39 PM
Posts: 4,457 Washington
madscientist
Washington
If mr PBody can't find his ill see if I still have mine.
If you are using aluminum rods and have an old junk one, it's easy to make one from it. I just make a drill sleeve if using an aluminum cap.
Pretty easy to make on with a steel cap too, you just have to lay it out.
[Re: madscientist]
#2073934
05/15/16 04:52 PM
05/15/16 04:52 PM
MR_P_BODY
Pretty easy to make on with a steel cap too, you just have to lay it out. Thats all mine is... just a cap but I torque the cap with the bearings in it each time and drill just the one bearing... mine just happens to be a production Viper rod
[Re: MR_P_BODY]
#2074892
05/17/16 01:06 AM
05/17/16 01:06 AM
madscientist
Washington
So far I havent found mine Oh crap I forgot about this. If he is still in need I'll see if I can find mine and get it to him. I'll look in the morning.
[Re: Bighead440]
#2084275
06/01/16 08:46 PM
06/01/16 08:46 PM
MR_P_BODY
Any luck finding an unwanted drill fixture? I guess I can try to make one, but I know the placement is critical as far as having the bearing parting line and tangs precisely located.. Just put a bearing in a rod cap and drill the cap.. make sure the cap is seated... I bolted both halves together first then unblolted it.. the bearing will stay there.. get a set of bearings so you know the hole size... and bolt each one together before drilling and I'm talking both bearings before drilling the one hole.. and make sure you have the right bearing (if it has a taper for the crank side)
[Re: Bighead440]
#2084291
06/01/16 09:08 PM
06/01/16 09:08 PM
madscientist
Washington
Any luck finding an unwanted drill fixture? I guess I can try to make one, but I know the placement is critical as far as having the bearing parting line and tangs precisely located.. Dammit I forgot to look. Grab and hang. I'm going to walk out right now and see if I still have mine. If I do, you can PM me and I'll send it to you. Hold on.
[Re: Bighead440]
#2084292
06/01/16 09:12 PM
06/01/16 09:12 PM
madscientist
Washington
FOUND IT FOUND IT FOUND IT.
Just PM me your mailing address and I'll send it out in the mail tomorrow morning.
It just slipped my freaking mind.
Anyway, no sense making one. I'll send ya this one.
[Re: Bighead440]
#2088507
06/08/16 06:45 PM
06/08/16 06:45 PM
madscientist
Washington
Did you get my PM, madscientist? Nope. Got the thing right here. Send it to me now since I'm on here. I'll go check, but I never got a notice you PM'd me.
[Re: Bighead440]
#2088508
06/08/16 06:47 PM
06/08/16 06:47 PM
madscientist
Washington
Just checked. Nothing in my inbox.
[Re: madscientist]
#2088516
06/08/16 07:03 PM
06/08/16 07:03 PM
MR_P_BODY
Just checked. Nothing in my inbox. Make sure your not over limit on PMs.. but it should tell him your over ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Bighead440]
#2088560
06/08/16 08:20 PM
06/08/16 08:20 PM
madscientist
Washington
Still nothing.
As soon as I get his address I'll get to the PO and send it off. I just need to know where to send it.
