Best Rocker arms for Eddy RPM heads?
#2088251
06/08/16 11:21 AM
06/08/16 11:21 AM
Posts: 1,051 The Great White North
RAMM
Looking for some real world experience on this. I know this shouldn't be a hard question to answer. Just wondering what people have found to be the best, the best as in --Accuracy(of ratio) , Geometry, Reliability. These are rockers I plan to use on this years EMC entry in the SPEC Bigblock class. Any advice would be welcome.
Hoping AndyF chimes in here and B3Re Thanks, J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: Best Rocker arms for Eddy RPM heads?
[Re: RAMM]
#2088312
06/08/16 01:09 PM
06/08/16 01:09 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd run the Comp ultra-pro magnums.
[Re: RAMM]
#2088318
06/08/16 01:18 PM
06/08/16 01:18 PM
Thumperdart
State of confusion
Older HS`s w/lash caps not perfect but good geometry and scrub and a solid Isky roller...........You didn't specify what cam you will run...........
[Re: Thumperdart]
#2088383
06/08/16 02:48 PM
06/08/16 02:48 PM
RAMM
Older HS`s w/lash caps not perfect but good geometry and scrub and a solid Isky roller...........You didn't specify what cam you will run........... You're right whoops, probably .710"+ hydraulic roller is mandated. J.Rob
[Re: fast68plymouth]
#2088384
06/08/16 02:49 PM
06/08/16 02:49 PM
RAMM
I'd run the Comp ultra-pro magnums. What specifically do you like about them? I've never used just kinda thought they looked heavy and therefore klunky. I also see they are no longer offered in a 1.6 ratio. Wonder why? J.Rob
[Re: RAMM]
#2088410
06/08/16 03:39 PM
06/08/16 03:39 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Another vote for Comp ultra pro magnums on Eddy RPM heads. The scrub is good and I also like that they require conventional ball/ball pushrods instead of ball/cup style. Had an issue with shaft galling with the earlier non-bushed pro magnums. The ultra pro magnums are bushed and have been trouble so far with with comp 951 springs and solid roller cam.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: RAMM]
#2088460
06/08/16 05:02 PM
06/08/16 05:02 PM
fast68plymouth
So. Burlington, Vt.
I'd run the Comp ultra-pro magnums. What specifically do you like about them? I've never used just kinda thought they looked heavy and therefore klunky. I also see they are no longer offered in a 1.6 ratio. Wonder why? J.Rob Afaik they were only ever offered in a 1.5, so I doubt that's going to work for you in this instance. As was already mentioned, the overall geometry seems to be pretty good with that rocker on those heads. They really aren't that heavy, and since most of the weight is closer to the shaft, my guess is they have a lower moment of inertia than the aluminum alternatives. For what you're looking to do, I think T&D is probably the way to go.
[Re: 71yelladustr]
#2089392
06/09/16 11:23 PM
06/09/16 11:23 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Another vote for Comp ultra pro magnums on Eddy RPM heads. The scrub is good and I also like that they require conventional ball/ball pushrods instead of ball/cup style. Had an issue with shaft galling with the earlier non-bushed pro magnums. The ultra pro magnums are bushed and have been trouble so far with with comp 951 springs and solid roller cam. You mean "no" trouble?
[Re: ahy]
#2089614
06/10/16 01:21 PM
06/10/16 01:21 PM
Posts: 561 USA
B3RE
USA
Jesse, I would use a rocker with a cup style adjuster, so that limits you a good bit. Also, are you planning on running the stock length valves in the Eddys and getting enough installed height elsewhere? There is going to be a whole lot more to this selection than just experience with other combinations, IMO. Rule specifics, and creative interpretation, are going to dictate which direction you will need to go. I think a custom T&D rocker and relocated shafts are likely going to be the solutions in this case. An off the shelf part number isn't going to do it. If you want to call me, I can explain in more detail. 717-497-6572
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#2089722
06/10/16 05:12 PM
06/10/16 05:12 PM
RAMM
Jesse, I would use a rocker with a cup style adjuster, so that limits you a good bit. Also, are you planning on running the stock length valves in the Eddys and getting enough installed height elsewhere? There is going to be a whole lot more to this selection than just experience with other combinations, IMO. Rule specifics, and creative interpretation, are going to dictate which direction you will need to go. I think a custom T&D rocker and relocated shafts are likely going to be the solutions in this case. An off the shelf part number isn't going to do it. If you want to call me, I can explain in more detail. 717-497-6572 I'm actually not looking to get into re-engineering the valvetrain on this year's EMC effort. I actually want to keep this as simple as possible and don't really want to ante up for T&D's this time. Installed height is 2.00" and .708" lift should be easily doable in this regard. I ordered the Comp Ultra-Pro Magnums and would like to maximize these. I appreciate the offer Mike and wouldn't mind calling you to pick your brain, perhaps next week sometime. J.Rob
[Re: RAMM]
#2089868
06/10/16 11:13 PM
06/10/16 11:13 PM
Posts: 561 USA
B3RE
USA
Jesse, I would use a rocker with a cup style adjuster, so that limits you a good bit. Also, are you planning on running the stock length valves in the Eddys and getting enough installed height elsewhere? There is going to be a whole lot more to this selection than just experience with other combinations, IMO. Rule specifics, and creative interpretation, are going to dictate which direction you will need to go. I think a custom T&D rocker and relocated shafts are likely going to be the solutions in this case. An off the shelf part number isn't going to do it. If you want to call me, I can explain in more detail. 717-497-6572 I'm actually not looking to get into re-engineering the valvetrain on this year's EMC effort. I actually want to keep this as simple as possible and don't really want to ante up for T&D's this time. Installed height is 2.00" and .708" lift should be easily doable in this regard. I ordered the Comp Ultra-Pro Magnums and would like to maximize these. I appreciate the offer Mike and wouldn't mind calling you to pick your brain, perhaps next week sometime. J.Rob Pick my brain? That'll be a short call. Seriously though, I'd be happy to chat with you.
Mike Beachel
