Re: Brass Lifter Bushing, where can i go?
[Re: Diablo]
#208786
01/30/09 06:43 PM
01/30/09 06:43 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Chenoweth speed and machine http://www.chenowethspeedandmachine.com/It's where I found the best deal. LSM was $$$$$ The I.D was .9045 when finished
[Re: Diablo]
#208788
01/30/09 07:22 PM
01/30/09 07:22 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Where can i go to purchase some 1 in Od and .904 ID Brass Lifter bushings?
Also since my lifter says its a .904 what is the actual ID on the lifter bushing suppose to be?
The bushings do not come in finished size like you are asking for . you do realize this is a very delicate operation that has to be preformed very accurately ?
[Re: Diablo]
#208792
01/31/09 12:16 AM
01/31/09 12:16 AM
JohnRR
Yes i know. And why i said brass i dont know. Just a quick typing error i guess.
my engine has bronze guides in it but they are for a .840 GM lifter..... (Dont get my started why that was done)
And it is seeming to me it is actually cheaper to put new Bronze guides in then actually boring out the .840 ones to the .904 i need.
Are you running a flat tappet cam ? Even if you knock out the old bushings and put in new they will need to be final sized .
I had a set of .875's put in a block and brought out to .904 , wasn't that expensive ...
[Re: Diablo]
#208793
01/31/09 09:56 AM
01/31/09 09:56 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I stock the BHJ bushings here. Let me know if you need some.
They are 1.00 OD and .9035 ID, slight hone required after install.
RIP Monte Smith
