Re: front oil over shocks
[Re: superchuck]
#2087405
06/06/16 11:00 PM
06/06/16 11:00 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Afco makes a coil over that bolts in your factory mounts. 3850m is the number for double adjustable shocks.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: superchuck]
#2087729
06/07/16 01:57 PM
06/07/16 01:57 PM
1967dartgt
Hilltown Pa
Not with out work to factory arm.
[Re: junior636]
#2087784
06/07/16 03:49 PM
06/07/16 03:49 PM
1967dartgt
Hilltown Pa
What needs to be done to the lower control arm? Guys have been running coil overs on factory lowers for years. Nothing needs done to lower. These shocks bolt on stock car. I had them on my dart when it had a fully stock front end with torsion bars.
[Re: superchuck]
#2087787
06/07/16 03:54 PM
06/07/16 03:54 PM
1967dartgt
Hilltown Pa
I talking about the space in the upper that the shock slides through. I'd hate to have to go tubular I don't think it will fit with the coil over spring installed on a stock upper a arm. I ran these with out the spring on my stock front end. I think it would requir some trimming to make them work. Standing them up straighter would only make that situation worse. I would just get some tublar uppers as they help with your alignment.
[Re: superchuck]
#2087835
06/07/16 05:26 PM
06/07/16 05:26 PM
Posts: 36 michigan
junior636
michigan
I talking about the space in the upper that the shock slides through. I'd hate to have to go tubular Not sure why you would hate to go to tubular uppers but a coil over WILL NOT fit with stock uppers and I wouldn't suggest starting to trim back the uppers.
