Re: 2003 dodge neon crank sensor code need help tried everything
[Re: moparmatt0]
#2087317
06/06/16 08:55 PM
06/06/16 08:55 PM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
What brand of sensors used?
Mo' Farts
Moderated by "tbagger".
[Re: moparmatt0]
#2087336
06/06/16 09:25 PM
06/06/16 09:25 PM
Posts: 228 NY
moparmatt0
NY
[Re: moparmatt0]
#2087348
06/06/16 09:59 PM
06/06/16 09:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
So, who's paying for all the unneeded parts and labor?
[Re: moparmatt0]
#2087474
06/07/16 12:32 AM
06/07/16 12:32 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Was the cam/crank sensor sync relearned in the PCM? This should preformed anytime the engine timing has been altered or the timing belt has been removed. Sometimes will set erroneous DTCs is not reset.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: moparmatt0]
#2087674
06/07/16 12:17 PM
06/07/16 12:17 PM
Posts: 6,020 Salem
Grizzly
Salem
I have found this to be the problem. The aftermarket sensors are junk. Had an aftermarket cam position sensor in the '04 Neon, tossed it and put a Mopar one in, check engine light disappeared.
Mo' Farts
[Re: moparmatt0]
#2087764
06/07/16 03:07 PM
06/07/16 03:07 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Alaso make sure the magnet is still on the back of the cam for the cam sensor as I have seen this missing before. Most Neons will run without the cam sensor but some are hard to start. The PCM will just try different firing orders while cranking until it gets it right and then once started it dont need to look at the cam sensor anymore once it knows the firing order as it will know what coil and injectors to fire. Ron
