Page 1 of 4 1 2 3 4
How to get .040" quench w/ open chambers? #2087213
06/06/16 06:31 PM
06/06/16 06:31 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
For small blocks. How is this achieved? Without going with closed chamber. This is for 10.5:1 91oct E10. Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087214
06/06/16 06:33 PM
06/06/16 06:33 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Quench pad pistons and lots of GOOD machining and measuring. You'd have to equalize all the "open" area of the chamber (probably have to machine them) and then cut the quench pads of the Pistons to give you your .040".
Re: How to get .040" quench w/ open chambers? [Re: WO23Coronet] #2087219
06/06/16 06:37 PM
06/06/16 06:37 PM
Its a TRAP!
Its a TRAP!
Have a piston recommendation (stock stroke 360)? Who does your machining? Kens? Comp?
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087224
06/06/16 06:44 PM
06/06/16 06:44 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
No I don't have a piston for you to use but I'm sure some of the SB guru's will have some recommendations. I used Millar Racing Engines in Winkler for a 440 I had rebuilt as a teen and it was a good engine. He has a pretty good rep to this day, maybe give him a call. Are you in Manitoba?
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087226
06/06/16 06:46 PM
06/06/16 06:46 PM
Its a TRAP!
Its a TRAP!
Yeah, peg. Winkler's a bit of a drive.
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087247
06/06/16 07:02 PM
06/06/16 07:02 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
There's a local BB guru (Mike Arsenault) who uses Competion Engine for his machine work. Mike builds some pretty stout BB's. He's got a 70 Satellite with a 588 B1MC that runs high 9's
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087251
06/06/16 07:11 PM
06/06/16 07:11 PM
Its a TRAP!
Its a TRAP!
Yahhhhh I know MIke. I'll go see the boys at Comp 2morrow. Thanks a bunch.
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087272
06/06/16 07:47 PM
06/06/16 07:47 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
When I did it, I hand ground all of the chambers to the same depth, then cut the deck a TON to get the pistons .070 out of the hole. It is a long time consuming project to hand grind each piston to clear the edge of the chamber from there!
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087312
06/06/16 08:49 PM
06/06/16 08:49 PM
Its a TRAP!
Its a TRAP!
Yeah KB has the rough cut pistons. Toooo much work for this cat.
I think a cam in the 108ish LS & 236ish @ .050 should be enough
to get by on 91 on the street. Thanks guys.
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087357
06/06/16 10:16 PM
06/06/16 10:16 PM
get some KB 372 pistons in the OS your block requires. narrow the rods to 1" for them (it says required with them). machine open chambered head recesses just enough to get em equal/level. As said carefull measureing/machining of piston plateau keeping in mind gasket choice to get the SCR range you are after for .035-.040 quench. You'd need to bore to size then mockup the 4 corners & rock the pistons & check heights plus square decking the block. Need a good machine shop that will work with you. with 91 you will need quench & 040 is the very max.
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087422
06/06/16 11:20 PM
06/06/16 11:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It Takes some work but like said it can be done a few different ways. One I remember doing had the block decked enough to have a KB107 come out of the hole, then clearanced for the head. I did the same on my old 340 with the KB243. It required some more work for clearance because it was a 4.100 bore.
I took the easier way on this 360, KB107, Zero Deck, Edelbrock RPM heads milled a little, and a Fel Pro 1008. 11:1 91 Octane 500HP(11.16@119.5@3525lbs)
68 Barracuda Formula S 340
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087607
06/07/16 10:11 AM
06/07/16 10:11 AM
Its a TRAP!
Its a TRAP!
Yeah I was thinking about it. The KB373 pistons @ .005 below deck, with a .040" compressed gasket should give me .040" quench. Correct?
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087684
06/07/16 12:32 PM
06/07/16 12:32 PM
the quench plateau is .085" above the piston perimeter. you'd want .035-.040" between that flat and the head flat
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087723
06/07/16 01:49 PM
06/07/16 01:49 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Then get a set of closed chamber heads if you aren't interested in doing the job right.
Getting .040 quench is not a throw it together task with as cast iron heads .
Re: How to get .040" quench w/ open chambers? [Re: JohnRR] #2087734
06/07/16 02:05 PM
06/07/16 02:05 PM
Its a TRAP!
Its a TRAP!
read post #2087607 Johnny-be-bad laugh2 But as per usual your right.. I'll do the quench pistons the right way.
Re: How to get .040" quench w/ open chambers? [Re: RapidRobert] #2087735
06/07/16 02:06 PM
06/07/16 02:06 PM
Its a TRAP!
Its a TRAP!
thumbs
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087739
06/07/16 02:16 PM
06/07/16 02:16 PM
you mean this ??
It makes no sense if you have an OPEN chamber head ????
Re: How to get .040" quench w/ open chambers? [Re: JohnRR] #2087741
06/07/16 02:20 PM
06/07/16 02:20 PM
Its a TRAP!
Its a TRAP!
you mean this ??
was talking about the .085" quench pad on top of the piston.
.005 below deck + .085 quench pad - .040 gasket should be .040 quench.. no? shruggy
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087751
06/07/16 02:39 PM
06/07/16 02:39 PM
P
Porter67 Offline
Porter67  Offline
P
Mr. Bush would say.....Fuzzy Math.
Re: How to get .040" quench w/ open chambers? [Re: DARTH V8Я] #2087757
06/07/16 02:52 PM
06/07/16 02:52 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It depends on how recessed the open area of your chamber is. Say it's .100", you have a .040" head gasket and the pistons are at zero deck, You'd need your quench pad to be .100" to get a .040" quench.
Page 1 of 4 1 2 3 4
