Poly urethane bushing problem
#2087034
06/06/16 01:55 PM
06/06/16 01:55 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
In less than 6000 miles ALL of the poly urethane bushings on my 4 link set up are trashed. I mean cracked and knarled ! The car sounds like a rattle trap that is going to fall to pieces when I make a turn. Anyone using a bushing that will last a while????
Driving modern convenience in classic beauty
Re: Poly urethane bushing problem
[Re: Darius]
#2087281
06/06/16 08:00 PM
06/06/16 08:00 PM
Posts: 43 Santa Fe Springs, CA
Jon @ Hotchkis
See if Energy Suspension or Prothane make a graphite-impregnated poly bushing for your application. Regardless of what bushings you end up using you will want to use a silicon-based or silicone-impregnated synthetic grease; Redline, Royal Purple, Mobile 1, and Neo make this type of grease. This grease is very durable and "clingy" so it doesn't wash out with water and your bushings will love it; you can also use it in ball joints and tie rods too.
Hotchkis Performance 8633 Sorensen Ave. Santa Fe Springs, CA 90670 Phone: 562-907-7757 x224 Fax: 562-907-7765
Hotchkis Performance East 9075 Highway 152 Mooresville, NC 28115 704-660-3060
[Re: Darius]
#2087408
06/06/16 11:04 PM
06/06/16 11:04 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
If it is a RMS 4 link I'm sure you can get rubber or poly bushings from them, I would also guess you could find some replacement rubber ones local if you are in California. I personally never use poly in any suspension parts in my cars, I will use it for transmission or body mounts but not for anything else.
A new iron curtain drawn across the 49th parallel
[Re: Darius]
#2087500
06/07/16 01:13 AM
06/07/16 01:13 AM
Posts: 22,696 Bitopia
jcc
Bitopia
I've used poly in various forms for over 30 years. It seems to have a finite lifespan, before it completely disintegrates. Reminds me of fire ant bites, somehow they all know to bite at same time, poly fails the same way. The strangest aspect, I often at the auto trade shows, like PRI, the exhibitors that have poly products, asked how and why the stuff fails, I get the tilted head blank stare dog look answer. I have stuff never been off the shelf, disintegrate, all colors, all conditions. Age seems to be the only common factor, and every item seems to have its own amount usable time. Yours ran out. I don't think it is a lubrication issue or type, that effects lifespan, contrary to popular thinking.
[Re: jcc]
#2087517
06/07/16 01:42 AM
06/07/16 01:42 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I get the tilted head blank stare dog look answer. That would be Nipper, the RCA dog.
[Re: Darius]
#2087602
06/07/16 10:00 AM
06/07/16 10:00 AM
Darius
Sacramento, Ca
Thanks for the input guys.
[Re: Darius]
#2087894
06/07/16 07:22 PM
06/07/16 07:22 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Search for, or make your own, Delrin bushings instead of polyurethane... I've had Delrin bushings for over 30 years in my UCAs and still a-ok like new. Sway bar end link bushings made of polyurethane eventually crumble apart... I'd like to replace them with Delrin.
Firm Feel sells Delrin LCA bushings.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Darius]
#2088008
06/07/16 10:30 PM
06/07/16 10:30 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'll take heims over poly.
Mopar to the bone!!!
[Re: Mopar Mitch]
#2088531
06/08/16 07:19 PM
06/08/16 07:19 PM
Posts: 16,148 Mesa, Arizona
dart4forte
Mesa, Arizona
Firm Feel is where I get my bushings. Give Dick a call. By the way, were they installed with pre-load?
Abe Lincoln
[Re: Darius]
#2089584
06/10/16 12:02 PM
06/10/16 12:02 PM
Darius
Sacramento, Ca
According to the folks at Ride Tech in the late 07-early08 time frame ( when I bought the 4 link from RMS) they had a bad supplier . This supplier used what THEY called "powder metal" for the sleeve. They resolved that issue and have not had a problem since. They are sending me FREE replacements!!
[Re: Darius]
#2089605
06/10/16 12:46 PM
06/10/16 12:46 PM
jcc
Bitopia
So, we are talking the urethane bushings failed in a RMS rear 4 link set-up, just to be clear? How does ride tech fit in?
[Re: jcc]
#2090047
06/11/16 11:18 AM
06/11/16 11:18 AM
Darius
Sacramento, Ca
RMS does not build the 4 link system, he buys them from Ride Tech. Bill builds the AlterKtion.
[Re: Darius]
#2090059
06/11/16 11:58 AM
06/11/16 11:58 AM
jcc
Bitopia
RMS does not build the 4 link system, he buys them from Ride Tech. Bill builds the AlterKtion. That is the first time I have heard that. Has that always been the case and still is currently?
[Re: Darius]
#2090093
06/11/16 01:06 PM
06/11/16 01:06 PM
67autocross
Manitoba Canada
I had a quick look at mine and it looks to me that they are rubber with a steel sleeve, thinking back Bill may have offered options for the bushings at the time. I would guess that if ride tech does make some of the parts it's the 4 arms that come in the kit as they come painted and all the brackets are made by RMS are bare steel. I
[Re: 67autocross]
#2090140
06/11/16 02:32 PM
06/11/16 02:32 PM
jcc
Bitopia
If one is using all solid normal hardness urethane bushings in a rear triangulated 4 link, and not driving only on the drag strip, the system by design has no real compliance to overcome its natural designed in bind issues. Urethane would likely fail in due time in those conditions. Rubber anywhere in the links would reduce that bind by allowing some compliance, IMO. The OP implied to me the whole bushing system had failed, and was urethane, if I understood the situation correctly.
