1974 w200 running warm. Normal for big block?
#2085727
06/04/16 06:37 AM
06/04/16 06:37 AM
Posts: 1,944 woodcrest, CA
magnum440d100
woodcrest, CA
1974 w200 with 1972 440/np435 trans.
Large 3 core aluminum radiator from "The Radiator Lady" probably Champion brand. New hoses New water pump New thermostat New radiator cap Original shroud on aftermarket radiator so there are gaps here and there No fan clutch. Direct mounted, and is a flex fan.
Cooling system was seriously neglected. Truck sat for over a decade non running. The coolant was muddy brown. Flushed about 6 times and finally came out clear. I bought the truck knowing it needed a radiator and shortly after the headgasket blew. I assume the mud was bars leaks dumped in there when the radiator blew.
Pre flush, truck ran 185*/190*.
Poured prestone flush in there and ran for a day, sat overnight. Pulled block drain plugs. Let drain, put plugs back in, and filled with distilled water. Ran until thermostat opened and then 10 minutes more. Cooled down, drained again, and repeat procedure. Finally pulled all hoses and flushed with garden hose in short bursts, even heater core.
After flush, truck ran 210*, idled in a drive through for about half an hour and she climbed to 220* or so. Once moving, came down to 200*
Water pump was replaced next day. Coolant overflow/return system installed the day after that.
With new radiator cap and overflow system on, cooling system didn't build pressure until after the second shutoff (ran for about 10 minutes, shut off for about 15 minutes, then ran another 10 minutes, then shutoff for 15 minutes, then ran another 10 minutes running errands.)
Truck runs 195* driving down the highway, but sit at a light will quickly jump to 210*-215* and takes a bit of driving to come back down.
Motor heat soaks to 230* but comes down fairly quick after started to about 210*.
Thermostat does work. Holding hand on cool hose until instant hot, and looking at the gauge shows the 180* thermostat opening around 175*
Cooling system was burped. I added very little at a time and waited for all gurgling sounds to stop, squeezed bottom hose as well as upper hose until no more bubbles or gurgling sound.
Everything was flushed and back flushed and then topped with 2 gallons of green concentrated conventional coolant and 2 gallons of distilled water. After running for a couple days, bright green coolant is dirty and coolant in overflow tank is brown. I'm thinking there's a pocket of crud somewhere, or it's the old freeze plugs that were pushed into the block, dissolving (previous owner).
What on earth am I missing? Do big blocks just run warm? I'm tempted to run an Efan but would rather correct this issue instead of doing a bandaid fix.
Re: 1974 w200 running warm. Normal for big block?
[Re: magnum440d100]
#2086009
06/04/16 07:50 PM
06/04/16 07:50 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
A solid fan will move more air also at idle
Are you sure on the temps, aftermarket gauge?
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2086027
06/04/16 08:24 PM
06/04/16 08:24 PM
Posts: 7,664 IN
ahy
IN
It sounds like it runs 195 rolling which is good and then warms up at a stop. Usually, warm at stop is air flow related. I bet a factory style fan + thermal clutch would keep it cooler at a stop vs the flex fan.
Best would be the big 7 blade fan used on BB's with HD cooling and matching HD fan clutch. Also, some foam tape or similar to seal the shroud to the radiator would help so air is pulled through the radiator.
One other thing to check is pulley ratio. These cool best if the fan and WP is at least slightly over driven (crank pulley bigger than WP pulley). If you do change pulleys to speed it up suggest you wait until you have a regular fan + clutch... flex fans have been known to loose blades at speed with bad results.
PS: No need for a BB to run warm. Mine does not. That said, if the water jackets are plugged they will. Sounds like you flushed yours out really well. There can be crud that flushing won't touch however. With the past poor cooling maintenance that could be the situation you have. The fix is to pull the freeze plugs and use tools (screwdriver, coat hanger ect.) and a hose or pressure washer to loosen it up and flush it out. It can be done in chassis. I would work on the fan situation first however to see if that fixes it.
[Re: ahy]
#2086176
06/05/16 02:11 AM
06/05/16 02:11 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I agree crud will fill the rear of the block. Pull the cup plugs and flush.
Leave the gun.......take the Cannoli's....Mike
[Re: ahy]
#2086607
06/05/16 08:22 PM
06/05/16 08:22 PM
magnum440d100
woodcrest, CA
That's a nice big fan! It will want the matching HD fan clutch. The clutch with the 5 blade MP kit is lighter duty. Good to know! Hopefully it holds together long enough for the trip. Then I can get a new HD clutch. But so far, for the little I ran it, it is throwing MASSIVE air. I can feel the air being pulled through the radiator, AT THE GRILLE! If this don't fix something, I don't know.
