SB cams
#2084926
06/02/16 11:38 PM
06/02/16 11:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
who on here is GOOD with SB cams.. I have a fairly big roller in my 416 which is a street/strip rod thats for DW... now its injected witha a Holley Dominator.. it made 590hp on the dyno but this is a 260/270 @50 with .640/.640on a 105 lsa installed at the same.. it lopes real hard and tends to load the plugs at idle.. been thinking something smaller on duration and a larger LSA.. or maybe one of the injection guys can help me out.. was thinking about leaning it out at idle... any help is accepted... now its a W-2 on pump gas.. on the street it runs WELL on 87 octane... its 10.4 compression.. I have W-5s that will go that will give me 10.8.... I need 7000 - 7200 rpm... I hit 7200 the other day and it was still pulling HARD... but this cam was a 8000+ cam... I dont know if I can have this reground to a wider LSA or not... just would like to calm the lope down some and help the idle
Re: SB cams
[Re: dizuster]
#2084962
06/03/16 12:25 AM
06/03/16 12:25 AM
MR_P_BODY
Mike , not sure if you're interested but I have a custom ground EFI flat tappet solid for a 416" project that never got off the ground.
252/256 on a 112 lsa with .550 lift. I know it's not a roller, but it's brand new. I'd give it to you if you could use it. Let me think about it Scott..was looking for more lift like .600+.... these heads flow 310 at .650 or.700 I forget which..... but I want to thank you EDIT I guess I could go 1.6 ratio on the intakes
Re: SB cams
[Re: MR_P_BODY]
#2084969
06/03/16 12:36 AM
06/03/16 12:36 AM
Posts: 4,457 Washington
madscientist
Washington
252/256 on a 112 lsa with .550 lift. I know it's not a roller, but it's brand new. I'd give it to you if you could use it. Let me think about it Scott..was looking for more lift like .600+.... these heads flow 310 at .650 or.700 I forget which..... but I want want to thank you Call Cam Motion and be done. If you core is on a 105 right now, I don't know if it can be reground more than about 108-109. I suspect you want to be 111-112 and that's a long way to go from 105.
Re: SB cams
[Re: madscientist]
#2084978
06/03/16 12:49 AM
06/03/16 12:49 AM
MR_P_BODY
252/256 on a 112 lsa with .550 lift. I know it's not a roller, but it's brand new. I'd give it to you if you could use it. Let me think about it Scott..was looking for more lift like .600+.... these heads flow 310 at .650 or.700 I forget which..... but I want want to thank you Call Cam Motion and be done. If you core is on a 105 right now, I don't know if it can be reground more than about 108-109. I suspect you want to be 111-112 and that's a long way to go from 105. I can deal with a 109 lsa..and the duration Scott said would be close, but I would like more lift for the heads sounds like some calls are in order.. unless the injection guys can help... people sure do look at it with all that lope... but if I'm not on the brakes decent it moves forward on every lope
Re: SB cams
[Re: MR_P_BODY]
#2085047
06/03/16 05:33 AM
06/03/16 05:33 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
260-268@ .050 on a 110lca and stick it in 3-4 advanced....Don't know how much lobe lift you can deal with, I use several of Comp's lobes and know them quite well.
As long as you have at least .650 at the valve it'll make good power. With more lift comes more headaches...but I like to run .700-.750 on street/strip stuff if I can. Brian
Brian Hafliger
Re: SB cams
[Re: Brian Hafliger]
#2085137
06/03/16 11:55 AM
06/03/16 11:55 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
As long as you have at least .650 at the valve it'll make good power. With more lift comes more headaches...but I like to run .700-.750 on street/strip stuff if I can. Brian That's pretty close to my Comp roller, 263/271° @ .050, .711/.719" at the retainer, 108° in at 104°.
Re: SB cams
#2085158
06/03/16 12:29 PM
06/03/16 12:29 PM
MR_P_BODY
As long as you have at least .650 at the valve it'll make good power. With more lift comes more headaches...but I like to run .700-.750 on street/strip stuff if I can. Brian I tried to keep the lift down some what to keep the spring pressure down also.. now it 265 on seat and just over 600 at lift..it pulls hard to 7200 for sure.. thats as high as I've gone so far
Re: SB cams
[Re: Twostick]
#2085175
06/03/16 01:01 PM
06/03/16 01:01 PM
MR_P_BODY
Are you running it closed loop at idle Mike?
I'm running a stone age Commander 950 Pro TBI on my 493 with a 248 @ .050 108 LSA and to get it to behave at idle/low RPM I had to set it to run alphanumeric under 1800 RPM. Idle is set at 1100.
Play with the idle fuel map in A/N until the idle is happy and let the AFR fall where it may.
Also add as much advance into the idle as you can to help clean it up.
You have a bunch more cam than I do but you should be able to coax it into some semblance of acceptable.
Kevin
Once it gets above 160* its a self learning system.. but I think I need to lean down the fuel idle..I have it idling at 900-1000 rpm.. it might need to come up some to help smooth out the idle... I'll have to plug in the puter to see what the idle A/F is...I havent even down loaded any programs yet .... I need to
Re: SB cams
[Re: MR_P_BODY]
#2085281
06/03/16 03:43 PM
06/03/16 03:43 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Could you mill your heads, run thinner head gaskets or find another way to add a point of compression? That tends to smooth out the idle in my experience and a switch to premium pump gas should be easy enough and the better MPG will help off set some of the higher price plus more HP, sounds like the way to go to me instead of compromising the cam in some way.
Re: SB cams
[Re: HotRodDave]
#2085352
06/03/16 05:33 PM
06/03/16 05:33 PM
MR_P_BODY
Could you mill your heads, run thinner head gaskets or find another way to add a point of compression? That tends to smooth out the idle in my experience and a switch to premium pump gas should be easy enough and the better MPG will help off set some of the higher price plus more HP, sounds like the way to go to me instead of compromising the cam in some way. Nope not gonna cut the heads anymore.. if I put the W-5s on with the .024 gaskets that will move it up right about 11:1...I'm cheap so it runs great on 87 octane with the W-2s at 10.4... should still run fine on 87 with the W-5s..I'll race on 93 with either set of heads.. its just the big overlap on this stick... I have a 22cc dish cut in these pistons to get it down to run pump swill
Re: SB cams
[Re: MR_P_BODY]
#2085386
06/03/16 06:09 PM
06/03/16 06:09 PM
madscientist
Washington
Did you call any cam people yet?
I was under the impression EFI would allow you to tune issues with fuel right out. Evidently, this isn't so.
Re: SB cams
[Re: madscientist]
#2085400
06/03/16 06:31 PM
06/03/16 06:31 PM
MR_P_BODY
I was under the impression EFI would allow you to tune issues with fuel right out. Evidently, this isn't so. I havent touched the injection yet..this is suppose to be a self learn system.. but with all the over lap this cam has I might have to help it and lean it down on idle.. above idle it runs great... since I first fired it up I havent put the computer on it... I will in a day or so and see what the fuel table says at idle... I'm sure its fat with all the over lap.... I had other issues that came first so now I can start looking at the fuel EDIT I have to down load the program thats in there before I even talk to anyone
Re: SB cams
[Re: madscientist]
#2085497
06/03/16 08:41 PM
06/03/16 08:41 PM
Thumperdart
State of confusion
I was under the impression EFI would allow you to tune issues with fuel right out. Evidently, this isn't so. NOTHING is completely self learning.............
Re: SB cams
[Re: Thumperdart]
#2085523
06/03/16 09:10 PM
06/03/16 09:10 PM
MR_P_BODY
I was under the impression EFI would allow you to tune issues with fuel right out. Evidently, this isn't so. NOTHING is completely self learning............. I would bet that if I didnt have this big overlap cam it would have had zero problems and would have learned it all that it needed... it doesnt even care if its a big duration cam.. if I had a 110-112 LSA it wouldnt have any issues... so big deal..I have to tell it what I want...on a computer.. thats real hard to do
Re: SB cams
[Re: MR_P_BODY]
#2085556
06/03/16 10:01 PM
06/03/16 10:01 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Some time tweaking the fuel tables will pay off nicely. There are some really good guys out there who can help you out if you are interested in paying for their time. I am using Chris at Performance Injection for my tunes. He knows what he's doing.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: SB cams
[Re: jbc426]
#2085616
06/03/16 11:16 PM
06/03/16 11:16 PM
MR_P_BODY
One of the guys here on the board was willing to help but he needs to see a program.. I still have to down load it
Re: SB cams
[Re: MR_P_BODY]
#2085679
06/04/16 01:31 AM
06/04/16 01:31 AM
Thumperdart
State of confusion
I was under the impression EFI would allow you to tune issues with fuel right out. Evidently, this isn't so. NOTHING is completely self learning............. I would bet that if I didnt have this big overlap cam it would have had zero problems and would have learned it all that it needed... it doesnt even care if its a big duration cam.. if I had a 110-112 LSA it wouldnt have any issues... so big deal..I have to tell it what I want...on a computer.. thats real hard to do Don`t trip Mike just saying nothing is completely self learned EXCEPT for ignorance...........
