Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2087492
06/07/16 01:01 AM
06/07/16 01:01 AM
Posts: 22,745 Bitopia
jcc
Bitopia
That's the move. Car will feel the road better as well. Have you factored in the belts, hoses, brackets and misc hardware to mount the old set up? You could be saving more LBS than you think. Yes, its all in the second pic, except the belt and the fluid, which might be offset by the heavier? single groove damper instead of the previous double groove set-up, not much difference regardless on those parts.
[Re: Thumperdart]
#2087608
06/07/16 10:13 AM
06/07/16 10:13 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Lee, I found a place that makes titanium fasteners and they claim to make custom parts. The carry regular flange and hex nuts, can't see why they couldn't make those castle nuts. http://racetechtitanium.com/
'71 Duster '72 Challenger '17 Ram 1500
[Re: Gary Robbins]
#2087676
06/07/16 12:20 PM
06/07/16 12:20 PM
fullmetaljacket
Yes HP is King, but most people have a modest amount of the natural aspirated kind that is not readily available because of the physical state of their rides and in this case, will probably lean over to trying to retrieve that available HP with less mass.
Personally, I like a manageable engine that scoots with out sweat and can last a long time as time is the main phenomenon that I don't have enough of when it comes to engine maintenance. Maybe its my lack of patience with such things. Funny enough though, I must admit that I do spend that unavailable time here and there fabricating stuff for the art sake of it anyway. Though power adders do make it more simpler and are finally the new breed of car on the street and strip, there are still a fair amount of carbureted mills out there and some, not all get it done on the Jenny Craig doctrine. I also suspect that the lag being witnessed in the performance scene these days is due to many heads that simply do not want to tune cars based on the new technology, but rather just turn screws. Old school vs new and improved and maybe its also a generational thing.
Talking about weight watching and with out a long story, shortly before the Cat came out of the bag at Dodge, I was in talks with the powers that be about a special limited edition "Alley cat" lightweight version of the HC and it was a horses hair from becoming a reality. Unfortunately some things came into play and it was cut off the balance sheet in the ninth inning. It would have been an animal along with some rather special features and collector merchandising never before presented by Dodge. Lets just say that I am very, very close to a test driver for all new makes coming down the pipeline, and I was impressed rather quickly on how powerful that Cat was, but the Fat Lady still bothered me. LOL.
[Re: Gary Robbins]
#2088463
06/08/16 05:14 PM
06/08/16 05:14 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
While admiring you weight watcher addicts I've come to the conclusion HORSEPOWER is what's KING with owning a Hellcat and a mid 7 second street legal car...Both get the job done with HP the Cat @4400# and the Fish @3250#....Yep both are power adder cars and if your not you might as well stay on the PORCH !! Impressive numbers on both. Lightweight cars take less abuse doing it and those numbers get better with less weight. I think knocking 500#'s off that Hellcat would shock a lot of people.
eBay-cdwmotorsports
[Re: FastmOp]
#2088517
06/08/16 07:03 PM
06/08/16 07:03 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have lost enough weight that I now need new springs.πΊπ»π Nice! Pics of progress? I really like that car
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2088595
06/08/16 09:17 PM
06/08/16 09:17 PM
fullmetaljacket
Here's something I fished out of the Formula one pond. "Minimum weight (kg) "Minimum weight (turbos) (kg) The rule makers believed excessively light cars had become an unacceptable hazard to drivers. In preceding seasons it was not uncommon for teams to drill holes in parts of their cars, such as the steering columns, to shave off weight in the pursuit of performance.
Unsurprisingly it was Lotus owner Colin Chapman, whose preoccupation with weight-saving bordered on obsession, who pointed out that light weight and safety were not necessarily mutually exclusive, and that recent fatalities had befallen drivers of the heaviest cars on the grid.
Chapman not unreasonably argued a heavier car is harder to slow down in a crash and dissipates more energy in an impact, making it more dangerous. But it was also true that many of his drivers were concerned his pursuit of low weight went beyond merely putting too little fuel in his cars and resulted in chassis that were too fragile and put them at greater risk".
There is reason here from both sides and people should be careful about what they do to their cars in the pursuit of Happiness in Performance. If in question, I always make it a point to have a frequent multi-point check on stuff just to be safe. This practice also finds potential problems that could/would be occurring without anything to do with weight loss, though like said above, less weight has the potential most of the time to keep breakage to a minimum compared to the heavy weights.
[Re: Thumperdart]
#2089869
06/10/16 11:14 PM
06/10/16 11:14 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Let us know how much ET you pick up from the 200lb weight loss..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 590 Challenger]
#2091911
06/14/16 05:05 PM
06/14/16 05:05 PM
cdwmotorsports
Martinsville, IN
I dumped 65-70 pounds this winter by dumping the dash, dash structure, steering column, kick panel structure, brackets (all under dash) mounted a little aluminum panel with tach and oil pressure Love the idea, but since the Demon is still streetable I refuse to dump the dash. The cage guy actually bent the bars wrong so it is sans dash now but has a trip to the chassis shop to get that issue fixed.
eBay-cdwmotorsports
