When I called Inline tube they said they would send me a new valve the little one that bolts to the big one. I hope that is what the problem is but I am thinking it may not be as I put on a used one that I cleaned out with brake clean and air and it still does the same thing, no fluid anywhere except the right front; any other ideas. Thanks
Avoid any proportioning valves from IN LINE TUBE, nothing but problems, if you need a PV valve get it from FINELINES, it may even have the same repro mfg's part number but FINELINES actually takes them apart corrects the valving/passage problems and test each unit before sales, unlike the other vendors
Mike
