Best tire for 4 speed hemi #2083602
05/31/16 08:57 PM
05/31/16 08:57 PM
central il.
second 70 Offline OP
central il.
I'm looking at tires for the rear of my 70 cuda 426 hemi approx. 600 hp 4-speed 4:10 strange s-track calvert split mono 9 way shock cal-tracks and QA-1 double adj. front. 3800#s without driver
Current nitto 275/60/15 worthless even at track.
It looks like the only tires that will fit are MT. ET. SS 275/60/15 or MT. ET. 28X11.5R15 bias #3554 or QTP 17601.
97% street driven is it worth the rough driving of a bias ply for traction over a better riding and poorer grip radial?
Re: Best tire for 4 speed hemi [Re: second 70] #2083730
05/31/16 11:23 PM
05/31/16 11:23 PM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
I would suggest the bias ply tire. I couldn't get a set of M/T 325R50-15 radials to hook either. Put on a set of 28x13.5x15 M/T ET streets and went 10.90s from dismal 12.00s at 129mph, no other changes. Radials don't seem to recover from the violent hit a clutch car has. You might get the radials to work with an adjustable clutch but I think your tuning window will be very narrow and wear will be high. My 2 cents...
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: Best tire for 4 speed hemi [Re: 6pak2go] #2083738
05/31/16 11:38 PM
05/31/16 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Seems to be the normal thing with a stick car.. just cant
take the shock on the hit.. thats why the bias work better..
on the street you might want the radials
wave
Re: Best tire for 4 speed hemi [Re: second 70] #2083745
05/31/16 11:50 PM
05/31/16 11:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run the same M/T ET streets on my Savoy and I'm kinda glad I get some spin at the hit. You really don't want a dead hook with a car that heavy twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best tire for 4 speed hemi [Re: second 70] #2083834
06/01/16 02:07 AM
06/01/16 02:07 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I have a set of MT. ET. SS 275/60/15's purchased this spring with one track outing on them I'll part with cheap. PM me if you're interested.
Re: Best tire for 4 speed hemi [Re: second 70] #2083912
06/01/16 09:01 AM
06/01/16 09:01 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You probably need different shock/air pressure settings for strip than street. Be careful how much bite you give the tires. I was breaking transmissions at 3,100 pounds and less than 600 hp with a 30 lb. flywheel, 5,000 rpm launch with too loose a shock setting. Ask Chip (an8sec70cuda) about his tire combo. He mentioned something once about mixing bias ply and radials giving him problems at the track. But I would probably go for a dedicated set of bias slicks for racing.
[image][/image]
Re: Best tire for 4 speed hemi [Re: sgcuda] #2084844
06/02/16 09:32 PM
06/02/16 09:32 PM
central il.
central il.
Thanks for the input I bought the MT bias ply et streets today
Re: Best tire for 4 speed hemi [Re: second 70] #2085105
06/03/16 11:09 AM
06/03/16 11:09 AM
an8sec70cuda Offline
Good choice. The radials won't work well w/ the 4 speed.
No problems at the track w/ any mix of tires I've ever had. My only complaint is w/ bias ply FRONT tires on the street...they follow ruts like train tracks. Doesn't matter what's on the back.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best tire for 4 speed hemi [Re: an8sec70cuda] #2085108
06/03/16 11:17 AM
06/03/16 11:17 AM
MI
MI Mopar Works Offline
MI
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Best tire for 4 speed hemi [Re: an8sec70cuda] #2085178
06/03/16 01:01 PM
06/03/16 01:01 PM
central il.
central il.
I agree Chip I run the same 28" sportsman on the front you do and they follow every grove.
Now I need to decide tubes or not? 4 speed need soft sideways and adding tubes stiffen sidewalls?
All this thinking is giving me a headache. Lol
Re: Best tire for 4 speed hemi [Re: second 70] #2085203
06/03/16 01:28 PM
06/03/16 01:28 PM
At your weight, I think the tubes would be good. Not to mention they keep the tires from leaking down. I used to run 28x12.5 ET Streets years ago and they'd lose a few lbs. overnight w/o tubes.
CHIP
Re: Best tire for 4 speed hemi [Re: an8sec70cuda] #2085208
06/03/16 01:41 PM
06/03/16 01:41 PM
central il.
central il.
I only weigh #150.
Re: Best tire for 4 speed hemi [Re: second 70] #2085211
06/03/16 01:44 PM
06/03/16 01:44 PM
Originally Posted By second 70
I only weigh #150.
OK, so one tube will easily keep you afloat in the pool. But for your car, I think 2 would be better.
CHIP
Re: Best tire for 4 speed hemi [Re: an8sec70cuda] #2085236
06/03/16 02:17 PM
06/03/16 02:17 PM
central il.
central il.
You've always been good at spending my money. Lol I bought a new set of Billet Street lites to go with them..and of course polished no black!!
Re: Best tire for 4 speed hemi [Re: second 70] #2085249
06/03/16 02:41 PM
06/03/16 02:41 PM
It gets better...if you run tubes, you have to either screw the tires to the rim or use beadlocks.
CHIP
