360 Ideas
#2083546
05/31/16 07:07 PM
05/31/16 07:07 PM
Posts: 870 Keizer, Oregon U.S.A.
elmor353
I have a sweet running, factory stock, 76 360 that that I would like to do some upgrades on. I picked up a factory spreadbore intake, 625 cfm AFB, 1 5/8 headers, Comp XE268 cam and springs. I know compression is going to hurt performance, but it's not in the budget to buy pistons. This engine is in my 68 Dart, 727 with factory high stall converter and 3.23 gears. Will this set up work? It doesn't run bad now, I would just like a little more.
Re: 360 Ideas
[Re: elmor353]
#2083580
05/31/16 08:13 PM
05/31/16 08:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Contrary to what you are likely to hear you will see a good improvement. You will hear you should do this or that but on a budget ou will do fine till you decide to step up
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: 360 Ideas
[Re: MoparforLife]
#2083593
05/31/16 08:41 PM
05/31/16 08:41 PM
RapidRobert
definitely get the right cam considering the low compression (I ain't sayin the 268 is not as I ain't a cam guy but confirm it is a good choice). Definitely dial in the dist subsystems/mixture/free flowing exhaust (takes a bit of creativity to have good flow but quiet enough to suit you (& your neighbors)
Re: 360 Ideas
[Re: elmor353]
#2083642
05/31/16 10:06 PM
05/31/16 10:06 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I've got a choice between 3.23 and 3.91's. I've run 3.91's behind a few big blocks, but it's a little steep for what I want on the street. I really don't know how I managed to live with 4.10's in my 69 GTX, but I guess when you're 23 you can put up with a lot more than at 63! lol I have seen Speed Pro h405cp pistons with rings, on ebay for $120, but it is only an increase to 8.6 with my open chambered heads. I agree that it's better than 7 something, but will I really see much of an improvement? Get the h405cp's and and with calculated decking you can get over 9:1. If you really want to wake it up, add some Magnum replacement (EQ) heads and burn rubber!
Re: 360 Ideas
[Re: cudadoug]
#2083669
05/31/16 10:32 PM
05/31/16 10:32 PM
RapidRobert
if it is running now & you dont want to pull the eng & go thru from head to toe (& it sounds like you dont), you just want bolt ons, what Doug said I would consider some JY mags. you would need mag rocker assys/oil thru pushrods (not sure if the JY eng would have the right length p rods but the guys here know) and a mag intake or mod yours. it would take some doing
Re: 360 Ideas
[Re: elmor353]
#2083848
06/01/16 02:46 AM
06/01/16 02:46 AM
RapidRobert
Think I'll bolt in what I've got and maybe add better pistons this winter. VG plan. People get caught up in this & end up with WAY too much down time. Summer is here! If desired build another killer eng at your leisure in your shop as time/money allow & that will let you do all of the little time consuming tricks that add up
Re: 360 Ideas
[Re: elmor353]
#2084068
06/01/16 02:27 PM
06/01/16 02:27 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The low compression and that cam will be soft on the bottom end but if you already have it you can install it and advance it about 4 degrees with an adjustable timing chain or offset key, even better if you know how to degree it and set it a few degrees advanced. It will run pretty good this way and the 3.23 gears I done one real similar, I even added magnum heads to that motor later and the gain was worth it. For pushrods you can get some 351 ferd PRs made for a factory roller cam engine aroun 1996 or so, you can actually get a nice hardened set of eddelbrocks in this length for real reasonable. They are not perfect but close enough to get ok geometry on a budget. I even used the GM V6 valve springs on that engine with the XE268 cam when I put on the magnum heads and it would pull cleanly to 6000. When compression is at a premium I buy one MLS head gasket (mr gasket has em cheap)seperate the layers and run the two thin layers coated with copper spray as individual steel shim head gaskets for a good duplicate of the factory steel shims, so far no issues doing this. You need to make sure your head and deck are TOTALLY clean and free of corrosion to make sure they will seal this way.
Disclaimer.... Some of my methods are not the best possible way but I have learned quite a few tricks to make someone faster on a shoestring budget so discuss them with others and use them at your own risk.
Re: 360 Ideas
[Re: HotRodDave]
#2084170
06/01/16 05:10 PM
06/01/16 05:10 PM
RapidRobert
When compression is at a premium I buy one MLS head gasket (mr gasket has em cheap)seperate the layers and run the two thin layers coated with copper spray as individual steel shim head gaskets for a good duplicate of the factory steel shims, so far no issues doing this. Dave, good info. is that the mr gasket 1121 gasket?
