fuel pressure droping ??? #2082004
05/28/16 09:11 PM
05/28/16 09:11 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Hey guys !!!!! Need some help with my fuel issue .... I got a 440 with a mechanical hv pump and when I first start my car the fuel pressure goes to 6 psi and stays there....once the motor gets hot I start losing fuel pressure ..it will go from 6 to 2 psi and the car will idle but if u go to accelerate it wants to die ! This pump worked on my other engine great so I Know that's ok ....what should I try next ? Anyone have this kind of problem ?? Thanks !!
Re: fuel pressure droping ??? [Re: fast414] #2082021
05/28/16 09:45 PM
05/28/16 09:45 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Not much help here but I will day good luck!
I had a Carter HV pump on my car and could not get it to work. Tried 2 of them. Same problem as you and I did a bunch of troubleshooting and hit a dead end - and I don't give up easily. Ended up going electric.
I even insulated all the fuel lines in the engine compartment and it did not help.
Re: fuel pressure droping ??? [Re: fast414] #2082025
05/28/16 09:56 PM
05/28/16 09:56 PM
RapidRobert Online content
RapidRobert  Online Content
plumb a can of gas in the eng compartment to the pump inlet & retry it. this will eliminate everything rearward from the pump as the culprit (2 short neoprene hoses/long hard line/pickup sock/tank venting). I've heard of the Carter Curse (referring to their mech fuel pumps) but you did say the pump worked fine before (but was it sitting on the shelf along time?)
Re: fuel pressure droping ??? [Re: fast414] #2082076
05/28/16 11:29 PM
05/28/16 11:29 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
It's a Holley pump and it Sat for about 3 yrs ....I will try the can of gas n see what happens ! Thanks
Re: fuel pressure droping ??? [Re: fast414] #2082096
05/29/16 12:17 AM
05/29/16 12:17 AM
canada
fast414 Offline OP
fast414  Offline OP
canada
B4 I do that tomorr .....any other suggestions ??
Re: fuel pressure droping ??? [Re: fast414] #2082121
05/29/16 12:54 AM
05/29/16 12:54 AM
got another pump you can toss in for a quick test (even a stock airtex)
Re: fuel pressure droping ??? [Re: fast414] #2082141
05/29/16 02:06 AM
05/29/16 02:06 AM
Andrewh Offline
Andrewh  Offline
I would check the line and where it is routing next to before the pump.
recent exhaust change?
I ran my fuel lines and stuff first then had exhaust put in.
had an electric pump along the frame rail infront of the wheel well.
genius exhaust guy routed the new exhaust as close as possible without touching.
could be something similar since it only happens when hot. could also be after the pump if the line is too close to the exhaust or block.
Re: fuel pressure droping ??? [Re: RapidRobert] #2082146
05/29/16 02:11 AM
05/29/16 02:11 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Re: fuel pressure droping ??? [Re: fast414] #2082275
05/29/16 12:46 PM
05/29/16 12:46 PM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
Had the same issue on my hauling truck i came to the conclusion that the diaphragm in the pump had a rip in it while it was pumping cool gas the rubber was stiff enough to prevent too much back flow bur as fuel got more warm from being circulated the rubber got softer and just couldnt make enough pressure also had similar issue with the mud truck but that was too much dirt in the tank clogging the sock hope this helps
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
