I ordered an RPM unit, I would assume 0-5 volts? Most common, correct?
Yeah 0-5 volt is the standard...been that way
for years... wish I could have found a few more
transducers when I was working.. they are all
basically the same.. K type thermocouples are
also the standard now for the temp spans we tend
to play within.. on my EGTs I use a 1/16"probe
just so it isnt blocking flow..I know the top fuel
guys use the big ones(I'm sure they are 1/4").. on
a probe like the EGTs.. the very tip is where it
reads.. just so you know
