Summit reman. 800cfm Thermoquad.. what do you think?
#2080761
05/26/16 04:23 PM
05/26/16 04:23 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
$305.. want to put one back on my wagon. Right now it has a 650 Edelbrock with the spacer. Kind of want to get more air and fuel into it! http://www.summitracing.com/parts/sum-210236/overview/
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Summit reman. 800cfm Thermoquad.. what do you think?
[Re: sunroofgtx]
#2080777
05/26/16 05:01 PM
05/26/16 05:01 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Get a new Street Demon 625. You can get remans for less off eBay direct from Holley, they work amazing. Better throttle response/torque than both my Quadrajet and the Thermoquad I tried earlier. They "stole" some Thermoquad ideas for the Street Demon but it is a cinch to tune by comparison.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: sunroofgtx]
#2080806
05/26/16 06:00 PM
05/26/16 06:00 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Heck ya! TQ over anything else all day long!
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: sunroofgtx]
#2080811
05/26/16 06:08 PM
05/26/16 06:08 PM
sunroofgtx
Cleveland
Shouldn't I go up in carb, not down? It's a 400HP. Thanks
[Re: sunroofgtx]
#2080818
05/26/16 06:17 PM
05/26/16 06:17 PM
DARTH V8Я
Its a TRAP!
Shouldn't I go up in carb, not down? It's a 400HP. Thanks 383HP used what? 625 cfm around there? 800 cfm will be fine IMO. Unless your talking about the demon carb..
[Re: sunroofgtx]
#2080827
05/26/16 06:28 PM
05/26/16 06:28 PM
sunroofgtx
Cleveland
305 seems great, unless what I read about Summits reconditioned units.. Out of spec from cleaning, tumbling,etc..
[Re: sunroofgtx]
#2080831
05/26/16 06:33 PM
05/26/16 06:33 PM
DARTH V8Я
Its a TRAP!
305 seems great, unless what I read about Summits reconditioned units.. Out of spec from cleaning, tumbling,etc.. Just like any other carb. Nothings perfect OOTB. Plus Summit has great C/S!
[Re: sunroofgtx]
#2081541
05/27/16 10:18 PM
05/27/16 10:18 PM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
A rebuilt carb is just one that's been cleaned and had gaskets replaced. They do not replace worn out items like throttle shafts[ think vacume leaks]. Scott at Harms rebuilds these correctly, taking care of the throttle shafts and other issues. When I worked at the parts stores years ago, there was a company called TOMCO. Our inside joke, which was too true, was that it meant "tomorrows comeback". Spend your bucks with someone who does the job correctly. C/S and "Lifetime warranty" don't mean squat.
Carl Kessel
[Re: CKessel]
#2081544
05/27/16 10:22 PM
05/27/16 10:22 PM
DARTH V8Я
Its a TRAP!
A rebuilt carb is just one that's been cleaned and had gaskets replaced. They do not replace worn out items like throttle shafts[ think vacume leaks]. Scott at Harms rebuilds these correctly, taking care of the throttle shafts and other issues. When I worked at the parts stores years ago, there was a company called TOMCO. Our inside joke, which was too true, was that it meant "tomorrows comeback". Spend your bucks with someone who does the job correctly. C/S and "Lifetime warranty" don't mean squat. Please. Summit isn't going to sell carbs with worn out throttle shafts. ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif)
[Re: CKessel]
#2081766
05/28/16 11:32 AM
05/28/16 11:32 AM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
A rebuilt carb is just one that's been cleaned and had gaskets replaced. They do not replace worn out items like throttle shafts[ think vacume leaks]. Scott at Harms rebuilds these correctly, taking care of the throttle shafts and other issues. When I worked at the parts stores years ago, there was a company called TOMCO. Our inside joke, which was too true, was that it meant "tomorrows comeback". Spend your bucks with someone who does the job correctly. C/S and "Lifetime warranty" don't mean squat. I agree. Scott is the go-to guy for a restored carb.
Abe Lincoln
[Re: sunroofgtx]
#2081938
05/28/16 06:30 PM
05/28/16 06:30 PM
Posts: 1,443 Maryland
Dads426
Maryland
The problem with thermoquads is the fuel bowl is very small and the gas evaporates out quickly. It seems that after 3-4 days, if you aren't running an electric fuel pump, it takes a lot of cranking to refill the bowls so it would start. And I did epoxy the wells and use new o-rings on the primary pickup tubes. It seems that if the level drops too low it won't pick up fuel to start. My 600 & 750 Edelbrock AFBs can sit for 2 weeks and start with no problem. The level in the bowl may be low, but it will still fire. The thermoquad ran great once it started, but I don't want to run and electric pump and it can be weeks before it is driven.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: sunroofgtx]
#2082092
05/29/16 12:10 AM
05/29/16 12:10 AM
sunroofgtx
Cleveland
Interesting.. Should I still put a spreadbore on it? I'd like to get the spacer off, and give my wagon some more fair and fuel.
[Re: Dads426]
#2082291
05/29/16 01:25 PM
05/29/16 01:25 PM
DARTH V8Я
Its a TRAP!
The problem with thermoquads is the fuel bowl is very small and the gas evaporates out quickly. The problem is today's fuel that evaporates fast. Back in the good old days, you could leave it for a month, hit the gas a few times & it'll fire right up.
[Re: sunroofgtx]
#2082310
05/29/16 01:55 PM
05/29/16 01:55 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
The problem is today's fuel that evaporates fast. Back in the good old days, you could leave it for a month, hit the gas a few times & it'll fire right up This is correct. Using fuel without ethanol does help this issue in most cases.
[Re: sunroofgtx]
#2082327
05/29/16 02:15 PM
05/29/16 02:15 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Rick I used an 800 Holley spread bore for years on my Savoy with a 77 iron intake manifold and worked well enough to put my low compression 440 in the 12's. It was dual feed double pumper but I don't think you can buy one new anymore. It was a very well mannered street cruiser and it was a direct bolt on to the TQ manifold. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: sunroofgtx]
#2083643
05/31/16 10:06 PM
05/31/16 10:06 PM
sunroofgtx
Cleveland
Might do that if I can find one like Gus was speaking of.. Thanks, guys.
[Re: sunroofgtx]
#2084660
06/02/16 03:40 PM
06/02/16 03:40 PM
sunroofgtx
Cleveland
Just bought a members new Holley Street Demon with the resin body.. Will try it out!! Thanks, Tom
[Re: sunroofgtx]
#2084868
06/02/16 10:04 PM
06/02/16 10:04 PM
DARTH V8Я
Its a TRAP!
Just bought a members new Holley Street Demon with the resin body.. Will try it out!! Thanks, Tom Lets us know what you think when it's up and running ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
