Re: Spool, truetrac, clutch sure grip or other for street/strip?
[Re: GY3]
#2080725
05/26/16 03:07 PM
05/26/16 03:07 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Take it apart, use a spring tester and find out what the factory springs are and replace them with some that are 200lb. stronger. There is also a video out there that tells about taking the cones out and machining the flat on the small end off so that they cannot bottom out in the housing. By doing the stronger springs and the machine work, the Auburn can work like it is really supposed to.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: jcc]
#2081256
05/27/16 01:17 PM
05/27/16 01:17 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
"Auburn type units are garbage, but you know that"
I unfortunately have come to that conclusion, AFTER I bought a new Auburn, my question, is there any low enough hp application that an Auburn will survive, like a healthy slant six? An Auburn will survive if you NEVER turn ...
Mainstream Media is the new Pravda
[Re: Slingshot383]
#2081259
05/27/16 01:20 PM
05/27/16 01:20 PM
JohnRR
A gulag near you.
Take it apart, use a spring tester and find out what the factory springs are and replace them with some that are 200lb. stronger. There is also a video out there that tells about taking the cones out and machining the flat on the small end off so that they cannot bottom out in the housing. By doing the stronger springs and the machine work, the Auburn can work like it is really supposed to. All that does is continue with it's pisspoor design , they self destruct everytime you turn. And that is only doable on the Borg Warner cone type , and don't forget to shim the side gears after machining the cones. the current design Auburns are not designed to be disassembled , once its not working anymore it's a door stop.
[Re: JohnRR]
#2081279
05/27/16 02:10 PM
05/27/16 02:10 PM
Posts: 4,804 Wichita
GY3
Wichita
I unfortunately have come to that conclusion, AFTER I bought a new Auburn, my question, is there any low enough hp application that an Auburn will survive, like a healthy slant six? An Auburn will survive if you NEVER turn ... I've been making really wide turns lately to prolong it's life until the Dana is done.
[Re: JohnRR]
#2081375
05/27/16 04:57 PM
05/27/16 04:57 PM
Posts: 23,275 Here
jcc
Here
I unfortunately have come to that conclusion, AFTER I bought a new Auburn, my question, is there any low enough hp application that an Auburn will survive, like a healthy slant six? An Auburn will survive if you NEVER turn ... But I really like my steering wheel
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: GY3]
#2081464
05/27/16 07:48 PM
05/27/16 07:48 PM
Posts: 247 Brisbane Australia
crash520
Brisbane Australia
Go the Dana path, I to spent many $$$ on eatons trutrac in an 83/4 but the noise was just beyond belief, now have a Dana truck, with ends, axles from Cass, Strange S-Trac and 3.7 gears,,,,, much happier
[Re: GY3]
#2082687
05/30/16 09:08 AM
05/30/16 09:08 AM
Posts: 1,514 Martinsville, IN
cdwmotorsports
Martinsville, IN
I have a spool for the Demon. The Grand Wagoneer has a Lockrite locker and it clicks all the time when turning, but it locks up right now when in the throttle.
eBay-cdwmotorsports
[Re: Uncle Barry]
#2083027
05/30/16 08:47 PM
05/30/16 08:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have a locker in my car with a Dana 60 and I absolutely hate it. I hear people talk how great they are and I just don't get it... Run a spool before you run a locker. At least it won't crack and bang lol. I ordered a S60 from Cass with the strange differential he talked me into. I hope it works good. Dont know what kind of locker you have but I run the Detroit Locker in my 8-3/4 and most of the time I dont even know its in there. Sure a little click now and then but thats all I ever notice. I hardly ever here noise from my locker that I can hear and I run a full exh out to the back of the car as my car is not all that loud. But with the Dana why not just run the factory posi/sure grip clutch pack setup ? We ran that for years in my brothers race car. Is the Strange diff you are getting a clutch type unit ? Ron
[Re: Uncle Barry]
#2084206
06/01/16 06:10 PM
06/01/16 06:10 PM
Posts: 1,734 central il.
second 70
central il.
I have a locker in my car with a Dana 60 and I absolutely hate it. I hear people talk how great they are and I just don't get it... Run a spool before you run a locker. At least it won't crack and bang lol. I ordered a S60 from Cass with the strange differential he talked me into. I hope it works good. You'll love it! I just changed from a true track to an S-tack and you can't even hear or feel it.
[Re: GY3]
#2084222
06/01/16 06:48 PM
06/01/16 06:48 PM
JohnRR
A gulag near you.
I just looked at the S-track .pdf and it looks like a just Eaton True Track but with a THRUST PLATE in the center.
[Re: GY3]
#2084352
06/01/16 11:12 PM
06/01/16 11:12 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
You guys are making me lean towards a spool for my street car. I ran a spool in all my cars over the years because they were also raced alot. The spools were ok but tend to be annoying when turning in a parking lot or if you are trying to push your car around in a driveway if the motor isn't done yet, it is almost impossible to push the car with the front wheels turned. But, I have a Duster with a stroked big block and if I decide to drive it to one of our local dragstrips and make a few fun passes, I'd have zero confidence in my cone-type factory posi unit(8.75). A spool with some 3.23 gears and some drag radials might have to be the way to go.
[Re: GY3]
#2084466
06/02/16 03:17 AM
06/02/16 03:17 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I ran a locker for a few years. It wasn't loud or anything, and it stood up to my abuse. Only thing I didn't like was that it pushed the car left & right when on & off the throttle. Wasn't really a big deal, until I started doing more bracket racing, and suddenly racing the stripe became an adventure when the car wanted to dart around at 115mph when I chopped the throttle.
I went to a spool this past winter, and I really can't figure out why people make a big deal out if it. Knowing what I know now, I'd choose a spool over the locker for a street / strip car. Sure the inside tire chatters on tight slow corners..... big deal.
[Re: ProSport]
#2084550
06/02/16 11:20 AM
06/02/16 11:20 AM
JohnRR
A gulag near you.
You guys are making me lean towards a spool for my street car. I ran a spool in all my cars over the years because they were also raced alot. The spools were ok but tend to be annoying when turning in a parking lot or if you are trying to push your car around in a driveway if the motor isn't done yet, it is almost impossible to push the car with the front wheels turned. But, I have a Duster with a stroked big block and if I decide to drive it to one of our local dragstrips and make a few fun passes, I'd have zero confidence in my cone-type factory posi unit(8.75). A spool with some 3.23 gears and some drag radials might have to be the way to go. I would put in a Detroit locker before a spool , if your exhaust is loud enough I doubt you'll here the clicking going around a corner. Strange only makes the S-track for the Dana 60 and 9 inch so it's not an option.
[Re: ProSport]
#2084566
06/02/16 11:50 AM
06/02/16 11:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You guys are making me lean towards a spool for my street car. I ran a spool in all my cars over the years because they were also raced alot. The spools were ok but tend to be annoying when turning in a parking lot or if you are trying to push your car around in a driveway if the motor isn't done yet, it is almost impossible to push the car with the front wheels turned. But, I have a Duster with a stroked big block and if I decide to drive it to one of our local dragstrips and make a few fun passes, I'd have zero confidence in my cone-type factory posi unit(8.75). A spool with some 3.23 gears and some drag radials might have to be the way to go. I had the cone style in my 8 3/4.. it lasted 600+ passes... but I spent a whole day(maybe more) lapping in the cones so they were perfect.. both tires hooked the same until the caps blew off.. then I changed to the alum center with a spool.. I drove a spool on the street for more than 5 years during the summer
[Re: StealthWedge67]
#2084581
06/02/16 12:26 PM
06/02/16 12:26 PM
383man
Balt. Md
I went to a spool this past winter, and I really can't figure out why people make a big deal out if it. Knowing what I know now, I'd choose a spool over the locker for a street / strip car. Sure the inside tire chatters on tight slow corners..... big deal. Its funny as I hear some say that about their Lockers but I have never had that happen with mine. It always stays straight and true on or off the gas in the traps. My exhaust is not real loud but I never hear much of the clicking. But a little electric fuel pump noise dont bother me either and I see alot complain about that also. I grew up with hearing the electric pump when the key was turned on as you knew it was working that way and it is a muscle car/hotrod so a little noise dont phase me any. But honestly I have never felt the side to side pull when on and off the throttle in the traps or anytime for that matter. Guess thats why I like my Detroit Locker so much and dont want to run a spool on the street. Course many have their prefrences and you have to use what you like. Ron
