Can dual plug Hemi Heads be run single plug? #2080142
05/25/16 04:00 PM
05/25/16 04:00 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Can dual plug Hemi Heads be run single plug by plugging the unused holes? If so, will a standard, single plug valve cover work? Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080144
05/25/16 04:05 PM
05/25/16 04:05 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
1. Yes
2. Yes(?)
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080165
05/25/16 04:50 PM
05/25/16 04:50 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
1. Yes
2. Yes
2011 Drag Pak Challenger
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080169
05/25/16 04:59 PM
05/25/16 04:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why not run the dual plug cover and fire just the
one plug
wave
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080193
05/25/16 06:13 PM
05/25/16 06:13 PM
Absolutely as long as you get the plugs and plug tubes in the correct locations on both heads scope
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080204
05/25/16 06:24 PM
05/25/16 06:24 PM
Parts unknown
590 Challenger Offline
Parts unknown
All the cool kids fire both!! All MSD inside, PM me if interested.
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080626
05/26/16 11:48 AM
05/26/16 11:48 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Go to page 5 of elephant hemi for sale, 1/3rd way down page. There is a pair of dual plug valve covers with both block off plates for sale.
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080650
05/26/16 12:43 PM
05/26/16 12:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Those superlightweight stamped aluminum Mopar covers that use the block off plates are unusable. You would be leaking more oil than the Deepwater Horizon.
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080660
05/26/16 01:08 PM
05/26/16 01:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Are all Hemi valve covers the same height top to bottom?
Re: Can dual plug Hemi Heads be run single plug? [Re: FastmOp] #2080697
05/26/16 01:41 PM
05/26/16 01:41 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think so.
Re: Can dual plug Hemi Heads be run single plug? [Re: Hemi_Joel] #2080709
05/26/16 01:52 PM
05/26/16 01:52 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
cast covers might be different in size,all the steel ones should be the same
Re: Can dual plug Hemi Heads be run single plug? [Re: FastmOp] #2080735
05/26/16 02:15 PM
05/26/16 02:15 PM
Definetily not! Street Hemi heads versus K heads and the different part numbers on the spark plug tubes makes me think that as well as how many spark plugs tubes I've seen with the bottoms pulled out by the spark plugs work I've seen two different Mopar brand spark plug tubes that use two different spark plug seals to the covers shruggyI seem to remember that the 1966/67 Street Hemi covers and tubes being different from the 1968 to 1971 street hemi covers, tubes and seals scope
I assembled one motor that had a set of KB cast alumnum covers on Dart aluminum water heads that required buying thier (KB) tubes to make the tubes fit correctly in those covers shruggy
