Re: New wheels, what Diameter are you guys going?
[Re: modelmakerinc]
#2079976
05/25/16 01:04 PM
05/25/16 01:04 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
For fronts, either 15" or 17"...you can get skinny tires in either size.
For rears, 15" has a way bigger tire selection and will hook better than the bigger sizes anyway. Unless you're talking pro mod size tires using the 16" rims.
A lot of the newer cars can't fit a 15" rim due to the brakes like you said. They run the big diameter stuff for a while. Eventually when they get enough power, they make the necessary changes and use 15" wheels.
[Re: modelmakerinc]
#2080152
05/25/16 05:25 PM
05/25/16 05:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wont tell you what I think of those BIG wheels on the street... but I have a name for them but wont say it... stick with the 15" unless your going pro mod.. you could also put some 22" rims on it with some rubber bands as tires for the true look ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2080190
05/25/16 07:07 PM
05/25/16 07:07 PM
Posts: 2,346 west palm beach, florida
modelmakerinc
Im thinking I didn't get my point across clearly. While looking through the selections/ options of Wheels and Tires in the "DRAG" categories, I am having to filter out the 16" and 17" and bigger wheel sizes, I was curious if this is a trend with Real Race cars or is it wheel selection for modern cars.
I am Needing 5" backspace to run a 315 or 325 on a 10" rim. I have Weld draglites with a 4.5 backspace and they are tight to the outside of the wheelwell. or I go to a 295 tire.
Not that the extra 1/2 inch of rubber is gonna make a difference anyway.
[Re: modelmakerinc]
#2080226
05/25/16 08:03 PM
05/25/16 08:03 PM
MR_P_BODY
You could roll the lip on the quarters... I'm running the 295/55/15 on my Rampage.. I run a 14x31x15 on the drag car.. I'm still playing with pressures and the ladder bars and shocks on the Rampage.. Radials are new to me ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2080518
05/26/16 09:07 AM
05/26/16 09:07 AM
Posts: 19,633 north of coder
moparx
I wont tell you what I think of those BIG wheels on the street... but I have a name for them but wont say it... stick with the 15" unless your going pro mod.. you could also put some 22" rims on it with some rubber bands as tires for the true look mr. p, i think i have the same name for those goofy big wheels as you do ! ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) and if i wanted to see gum band fork lift tires, i would go back to work. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: modelmakerinc]
#2080519
05/26/16 09:11 AM
05/26/16 09:11 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
If you're running a tall tire, the only choices are 15" IIRC...
Swap between 315/60 and 325/50 on this:
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
