To vent, or not to vent. That is the question. #2079753
05/25/16 01:41 AM
05/25/16 01:41 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Which gas cap do I need for my car? Vented or non-vented?
1970 Coronet, does NOT have California emissions package.
I’m listening.
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2079770
05/25/16 02:07 AM
05/25/16 02:07 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
For a non-ECS car I'm going to say vented.
http://www.allpar.com/fix/fuel/evaporation-control.html
Re: To vent, or not to vent. That is the question. [Re: Neil] #2079848
05/25/16 09:19 AM
05/25/16 09:19 AM
I ain't for sure if this applies but does it have the mini vent hard line attached to the filler neck inside the trunk? I would think with that, that you would not want extra venting in the cap???
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2079921
05/25/16 11:34 AM
05/25/16 11:34 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
vented
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2080476
05/26/16 02:41 AM
05/26/16 02:41 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Besides being vented or not....
Note that in 1970 Dodge and Plymouth used (2) caps with different size tabs. 1 had narrow tabs for the cam and 1 had wider cams....
Just my $0.02... wink
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2080530
05/26/16 09:55 AM
05/26/16 09:55 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Narrow tab, vented.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2080546
05/26/16 10:41 AM
05/26/16 10:41 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The vented ones will at least not let your tank form vaccum inside from fuel withdrawl if the tank vent lines ever get plugged. On my car, someone put in the wrong year fuel tank and plugged all the vents hoses. I had to put on a vented cap because my tank would suck shut while driving.
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2080715
05/26/16 02:59 PM
05/26/16 02:59 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
My twocents here. I thought the B-bodies with their flat tanks and filler necks behind the license plate used non-vented caps. That is the reason there is a vent line that goes from the tank, up through trunk floor, up wheel well and back out. The vent line forms a gas trap that ensures proper gas path. I recall reading that vented caps could expel fuel from a slug of fuel sloshing against the cap on hard acceleration. I always make sure the vent is clear and have always used non-vented caps. Never had an issue.
I think e-bodies and chargers where the filler neck is far above fuel level used vented caps (depending on ECS requirements).
Anyone have a parts book or manual handy?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: To vent, or not to vent. That is the question. [Re: RoadRunner] #2081065
05/27/16 01:13 AM
05/27/16 01:13 AM
Spokane Valley, WA
Spokane Valley, WA
Well, here's the one I bought. http://www.classicindustries.com/product/mopar/parts/st10632.html
I'm hoping it's the correct unit and that the picture is wrong (says "non vented") I didn't notice till After the purchase. The cam may not be right either. I guess I'll see. Thanks for the advice, gents. It's crazy the basic questions you need to ask when your car came to you in boxes and half the parts missing.
I’m listening.
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2081684
05/28/16 04:28 AM
05/28/16 04:28 AM
Spokane Valley, WA
Spokane Valley, WA
GAHHH! Wrong one. Got the non vent type. Guess I'll see if the cams fit. Rats.
I’m listening.
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2081711
05/28/16 09:15 AM
05/28/16 09:15 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
You got the correct one. Non Vented fits your Bee. If you installed a new tank, make sure the vent lines are hooked up to the correct tank nipples. The Spectra Premium tank I installed in my '70 Bee had the vent nipples reversed. The long line in the tank that goes all the way to the back connects to the short vent line clipped to the crossbrace above tank, and the short line nipple connects to the vent line that passes up into the trunk.
Re: To vent, or not to vent. That is the question. [Re: Pynzo] #2081768
05/28/16 11:41 AM
05/28/16 11:41 AM
Spokane Valley, WA
Spokane Valley, WA
I got both vent lines connected but did it over a year ago and can't recall which one I connected to which hose. I know I consulted the FSM. But in the end I think I connected the one closest to the hole for the trunk tube to that tube. I'll get under and check.
I’m listening.
Re: To vent, or not to vent. That is the question. [Re: Big Bad Bee] #2081832
05/28/16 01:48 PM
05/28/16 01:48 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
As long as it's the original tank you won't have any problems. It's the aftermarket you have to be careful with. You can see the vent lines from the filler tube opening.
