Re: New cam or ?
[Re: EDDIEB]
#2079873
05/25/16 10:16 AM
05/25/16 10:16 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
You didn't mention anything about a return line in your fuel system...you don't have that pump deadheaded do you?
Re: New cam or ?
[Re: EDDIEB]
#2080590
05/26/16 11:44 AM
05/26/16 11:44 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I doubt it's the fuel system, but the only flow test that tells you anything relevant is one done with a restrictor(or valve) in the discharge line adjusted to that you are flowing at what you feel would be the lowest acceptable system pressure(around 5lbs). Then time how long it takes to fill a gallon can while maintaining that pressure. Free flow tests are of essentially no value in determining if the fuel system is adequate for the application.
Re: New cam or ?
[Re: EDDIEB]
#2080606
05/26/16 12:08 PM
05/26/16 12:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yes I have a return line a -8 How much fuel do you use from pit to pit...what size is the vent.. are you using a roll over valve. they tend to be on the small side... when you do a flow test is the cap on the fuel system(like it would be driving)... and as said.. flow through the orifice (I like to pull the float bowls and set them in the bucket so they are upright
