Car wants to stall after car wash #2078091
05/22/16 02:42 AM
05/22/16 02:42 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I recently did a thorough car wash with lots of undercarriage splash. The engine stalled during the wash and it's been running a bit rough since. It also seem to want to stall every time I stop for a red light. Any ideas what could be causing this?
1973 Dodge Charger SE 400 automatic transmission. Curb weight: 3800 lbs. All stock so far. Goal: Reliable everday driveable warmed up 400 as close to 400hp as possible, then a 470 stroker if need be. Don't protect a feminist when the collapse comes!
Re: Car wants to stall after car wash [Re: xyxxjx] #2078092
05/22/16 02:50 AM
05/22/16 02:50 AM
hooziewhatsit Offline
water/condensation under the distributor cap is where I'd start.
Re: Car wants to stall after car wash [Re: xyxxjx] #2078093
05/22/16 02:50 AM
05/22/16 02:50 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Moisture, water, on the inside of the distributor cap.
Never mind.
Someone else beat me to the keyboard, for an answer.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Car wants to stall after car wash [Re: xyxxjx] #2078119
05/22/16 09:04 AM
05/22/16 09:04 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
could also be 'leaky' plug wires but the cap would be my first choice
Re: Car wants to stall after car wash [Re: mikemee1331] #2078127
05/22/16 09:50 AM
05/22/16 09:50 AM
IN
ahy Offline
ahy  Offline
IN
Cap and wires would be first choices. Another would be the highly power feed wires.
Specifically the bulkhead connector and the fusible link connections near the fender relay. I have seen water put a marginal connection in trouble. To test, turn lights and heater on and feel (carefully!) for warmth in these areas.
Re: Car wants to stall after car wash [Re: ahy] #2078238
05/22/16 01:31 PM
05/22/16 01:31 PM
as said, I'd grab your air hose/nozzle & start blasting
Re: Car wants to stall after car wash [Re: xyxxjx] #2078487
05/22/16 10:48 PM
05/22/16 10:48 PM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
What happens if water spray have gotten sucked in through the air filter?
Re: Car wants to stall after car wash [Re: xyxxjx] #2078492
05/22/16 10:54 PM
05/22/16 10:54 PM
other than the possibility of some of the filter element getting wet and soggy & shredding (& I dont think that is an issue) then as far as the eng ingesting a slight spray, no worries there
Re: Car wants to stall after car wash [Re: xyxxjx] #2078493
05/22/16 10:55 PM
05/22/16 10:55 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Nothing wrong with a little water in the carb, as long as you didn't try washing the engine out with the hose.
Re: Car wants to stall after car wash [Re: xyxxjx] #2078561
05/23/16 12:23 AM
05/23/16 12:23 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You can pour a gallon of water down the carb, as long as it stays running, it is not an issue on that end, I would look at the electrical like everyone else has noted...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Car wants to stall after car wash [Re: xyxxjx] #2078945
05/23/16 05:45 PM
05/23/16 05:45 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Back in "the day" , this was a common problem after taking your car to the "25 cent" car wash..
99% of the time it was water under the distributor cap..
Have you taken it off and wiped it dry then sprayed it with WD40 yet?? Probably the thing to do before you post anymore questions on here...
Re: Car wants to stall after car wash [Re: minivan] #2079164
05/24/16 01:52 AM
05/24/16 01:52 AM
xyxxjx, post all you want & holler how it turns out. even tho WD40 is technically a Water Displacer I would not use it in the cap & just blast it dry inside it & call it a day
Re: Car wants to stall after car wash [Re: xyxxjx] #2079184
05/24/16 03:12 AM
05/24/16 03:12 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I took the cap off it apears to be new, and it was completely dry. The spark plug wires visually apeared ok. The idle is still not too good but appears slightly better than a few days ago so maybe something is drying up. The idle seems ok in park when the engine has warmed up a bit, but terrible for the first few minutes. When I put it in drive the rpm drops and the car is shaking a lot, feels like it wants to stall. The first video is shifting from park to drive and back again. If you turn up the sound you can hear it better. Also what is the high pitched sound over the rumble of the engine? Seems like it got a bit louder. The second video is of the firewall in the engine compartment.
http://sendvid.com/eb8iwult?secret=ac1b02b2-67f0-4dce-9b11-c8416c55b38c
http://sendvid.com/mpjw9ex8?secret=d766727b-9233-4ef3-a957-106c3213b593
Re: Car wants to stall after car wash [Re: xyxxjx] #2079185
05/24/16 03:22 AM
05/24/16 03:22 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
That's a commiefornia emissions car eh? Noticed a lot of emission controls were disconnected, also, change that filthy air filter.. and fix that spaghetti wiring yikes.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Car wants to stall after car wash [Re: DARTH V8Я] #2079187
05/24/16 03:40 AM
05/24/16 03:40 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
Will get new airfilter. Yeah the wiring looks nightmarish shocked
Do you think I need a new bulkhead connector from what you can see?
Re: Car wants to stall after car wash [Re: xyxxjx] #2079191
05/24/16 03:54 AM
05/24/16 03:54 AM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Can't see the bulkhead (too much in the way). Disconnect it and look for corroded and/or burnt terminals. Make sure to take the positive battery cable off first for safety reasons.
Re: Car wants to stall after car wash [Re: DARTH V8Я] #2079194
05/24/16 04:16 AM
05/24/16 04:16 AM
Los Angeles CA
xyxxjx Offline OP
xyxxjx  Offline OP
Los Angeles CA
I always thought the negative terminal had to be disconnected first.
Re: Car wants to stall after car wash [Re: xyxxjx] #2079231
05/24/16 10:16 AM
05/24/16 10:16 AM
either one is fine. I think that the neg one is a good practice cuz with a wrench on the positive cable bolt if you get it horizontle & it touches some nearby metal such as the batt holdown which is grounded, sparks will fly but not so if the same thing happens working on the neg cable
Re: Car wants to stall after car wash [Re: xyxxjx] #2079254
05/24/16 11:02 AM
05/24/16 11:02 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Even a slight amount of moisture inside your cap will cause problems, my reason for recommending a "water displacer"...
Did you at least blow it out with air?
Re: Car wants to stall after car wash [Re: RapidRobert] #2079465
05/24/16 06:10 PM
05/24/16 06:10 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Correct, auto mechanics 101. A blown up lead acid battery is a sight to behold.
