Re: Exhaust suggestions
[Re: Tinman761]
#2074306
05/16/16 01:37 AM
05/16/16 01:37 AM
Posts: 221 Illinois
Tinman761
Illinois
No problem. 67 383-4bbl budget? Free of course. I'm not sure what a resto exhaust would cost
[Re: Tinman761]
#2074441
05/16/16 12:19 PM
05/16/16 12:19 PM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
I went with Gardner, however...
The angle of the "cup" to the drivers manifold was off and leaked. Since the HEMI head pipe mount is that rounded "ball and cup" type joint, it still connected, but barely. I eventually removed the system, cut out a slight wedge, bent it into place and welded it into a better angle. I still had to use a hand made gasket and use some gasket sealer to stop the "tic-tic-tic...". Gardner claimed it was my use of repop manifolds. Maybe the leak was due to the repop but not the off angle. Other than that, very nice materials and construction. Looks very original.
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
[Re: B5Cuda440-6]
#2074862
05/17/16 12:24 AM
05/17/16 12:24 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Does ECS make the exhaust for that application? I checked their website and it only shown 68-70 B-Body options. True ECS is more costly, but the fit and look are exact. I didn't think they would so I list Accurate
[Re: Morty426]
#2075377
05/17/16 09:41 PM
05/17/16 09:41 PM
Posts: 737 Michigan
BlueRacer69
Does ECS make the exhaust for that application? I checked their website and it only shown 68-70 B-Body options. True ECS is more costly, but the fit and look are exact. I didn't think they would so I list Accurate Same here, Accurate LTD. Nice system.
[Re: Tinman761]
#2075736
05/18/16 11:41 AM
05/18/16 11:41 AM
Posts: 75,112 A Banana Republic near you.
JohnRR
No problem. 67 383-4bbl budget? Free of course. I'm not sure what a resto exhaust would cost What are you using for exhaust manifolds ? The 383 in 67 I do not think used the HP manifolds so they would be LOG manifolds with a 2" outlet and did that car even have the option of duals ?
[Re: Tinman761]
#2076205
05/18/16 11:48 PM
05/18/16 11:48 PM
Posts: 3,691 MO
cdp
MO
you may try http://www.waldronexhaust.comI bought a kit for a 71 383 RR. Yet to install, but home to have it in within a few months. If they don't have it listed, call them, because they have a book/print to bend by. Full turndown kit was around $650 shipped.
[Re: floyd]
#2077135
05/20/16 03:06 PM
05/20/16 03:06 PM
Posts: 395 Milan Ohio
ct440rod
Milan Ohio
Just installed a accurate exhaust 70 challenger fits great
