Page 3 of 3 1 2 3
Re: 383 build [Re: fast68plymouth] #2078658
05/23/16 03:58 AM
05/23/16 03:58 AM
Portland, OR
Banzaiii67 Offline
Banzaiii67  Offline
Portland, OR
KB 162 Pistons have had two different designs..
I have an older version in my 383, the new 162's are rated for 8cc now.
Re: 383 build [Re: Abodysforever] #2078798
05/23/16 01:28 PM
05/23/16 01:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Like you would ever need valve pockets that deep(the new version) in any application where that was a suitable piston.
Just another example of someone not understanding what the market really needs.
Re: 383 build [Re: fast68plymouth] #2078832
05/23/16 02:18 PM
05/23/16 02:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That has pretty much been the business model of United machine regarding their Mopar pistons from day 1, in my opinion.
Re: 383 build [Re: fast68plymouth] #2078833
05/23/16 02:21 PM
05/23/16 02:21 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
To Russ's point, I don't know if correct height 1968/69 hp 383 pistons were ever available.
I've never taken apart an original 68/69 hp 383....... Did those motors actually have positive deck height pistons as delivered from the factory?
No, they were like .020 down
Re: 383 build [Re: GTX MATT] #2078834
05/23/16 02:23 PM
05/23/16 02:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , they are down .0025 -.003 at blueprint , positive .020 is the NHRA spec.
Factory piston CH of the 68-69 383 is 1.932
Re: 383 build [Re: Abodysforever] #2078835
05/23/16 02:28 PM
05/23/16 02:28 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Well the one I took apart was no where near 0 deck, this was with '70 pistons. It was right around .020 down, maybe a little less, but it wasn't single digit or anywhere close. .020 down with a stock head gasket would be right around 9:1...
Re: 383 build [Re: Abodysforever] #2078925
05/23/16 05:12 PM
05/23/16 05:12 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think the 70 piston is shorter than the 68-69 piston.
Page 3 of 3 1 2 3
