Burnout help #2076876
05/20/16 01:16 AM
05/20/16 01:16 AM
Wyoming
mechanic190 Offline OP
Wyoming
My first drag race is this weekend with this truck since 2010. I built a stock 360 with a big cam and can only foot brake the trans 2500 Rpms. In the meanwhile of the truck being parked for 4 years and not running my line lock solenoid [censored] the bed before even being used, so I will be brake standing her for the first race to burnout. I've done some test passes on the vacant street across from the house and cannot get a good second gear burnout. I've tried just a couple times with water and have to start in first gear to get them spinning and every time I try to hit second the tires come to a dead stop. This cannot be good for the trans. What can I do in such short time? Buying a new solenoid or not going is not an option.
Re: Burnout help [Re: mechanic190] #2076881
05/20/16 01:20 AM
05/20/16 01:20 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Just do a first gear burn out. No rule says you have to use second. If they heat up in first, you're good to go.
[image][/image]
Re: Burnout help [Re: mechanic190] #2076885
05/20/16 01:26 AM
05/20/16 01:26 AM
Wyoming
Wyoming
Been reading the horror stories of 727s blowing up from first gear burnouts and would rather not have it happen to me
Re: Burnout help [Re: mechanic190] #2076895
05/20/16 01:33 AM
05/20/16 01:33 AM
sgcuda Offline
sgcuda  Offline
I think third gear burnouts are the bigger problem, when they get into the overrunning clutch. Besides, I don't think your engine is going to make enough power to hurt the trans if you can't keep the tires spinning in second gear.
[image][/image]
Re: Burnout help [Re: sgcuda] #2076903
05/20/16 01:40 AM
05/20/16 01:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Years ago I would start my burnouts in first before I realized the damage it can do to the overrunning clutch (sprag) as I would hit the gas and then instantly shift into second and then third. I got away with it years ago but as I said as soon as I hit the gas I would shift right into second right away. Its not recomended but many did it for years and if you have to do it if you cant get them to spin even in water then shift right into second right away. But I would think in water you should be able to get them to spin in second. You want to be careful if you start the burnout in first as you dont want to damage the sprag and cause a problem where the drum can spin at high rpm and blow apart if you run a stock drum in the trans. Ron
Re: Burnout help [Re: mechanic190] #2076904
05/20/16 01:41 AM
05/20/16 01:41 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you dont want to come out of the water in 1st gear in a 727...and let it hit dry pavement...boom...
Tony
70 AARCuda Vitamin C
Re: Burnout help [Re: mechanic190] #2076927
05/20/16 02:34 AM
05/20/16 02:34 AM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
Step on it harder wile in 2nd gear. Don't ease into it.
Re: Burnout help [Re: mechanic190] #2076940
05/20/16 03:01 AM
05/20/16 03:01 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You have a non LBA valve body?
Re: Burnout help [Re: GTX MATT] #2077022
05/20/16 10:43 AM
05/20/16 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If he has a stock trans it is a LBA.. if you start
in the water(right at the front edge of the water
and your sifter is in second it is still starting
in first gear... if you pull it into low your appling
the sprag also.. as soon as they start spinning shift to
second... first/low is when you can have issues... DONT
spin it then let off and hit it again.. thats when you
break the sprag.. it rolls back then when you hit it again
that extra travel/distance will SLAM the sprag and break it..
if you spin off the line DONT pedal it.. shift out of low
also you have to set the sprag.. when you pull up
to the line.. have it in low and roll for about 4'
to set it.. if you back up make sure you have at
least that 4' going forward inlow
wave
Re: Burnout help [Re: mechanic190] #2077052
05/20/16 11:45 AM
05/20/16 11:45 AM
Wyoming
Wyoming
Thanks for the tips guys. My trans is complete stock rebuild with a TF 3 shift kit biggest problem is the 3.23 gears doesn't match my cam and not having the line lock adds that much more drag right on the top
Re: Burnout help [Re: mechanic190] #2077059
05/20/16 11:54 AM
05/20/16 11:54 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
To be honest you said you have a big cam,stock trans,3.23 gears, heavy truck you probably don't even need to do a burn out. it probably wont even spin the tires with a sticky track with big cam that wont make any low end torque. just saying.
JAKES AUTOMOTIVE
Re: Burnout help [Re: JAKE68] #2077062
05/20/16 12:02 PM
05/20/16 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Very true.. might be better off driving around the
water box.... at least try it once to see
wave
Re: Burnout help [Re: JAKE68] #2077148
05/20/16 03:29 PM
05/20/16 03:29 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This right here........Stock 360, big cam, stock trans, heavy truck, no gear.........Drive around the water and stage it
Re: Burnout help [Re: mechanic190] #2078587
05/23/16 01:02 AM
05/23/16 01:02 AM
Wyoming
Wyoming
Well drove through the water got them spinning in 1st gear and shifted to second not an issue unless i didn't get fresh water
Re: Burnout help [Re: mechanic190] #2078657
05/23/16 03:47 AM
05/23/16 03:47 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
are you using slicks or street tires? street tires do not need a burnout, all they do is drag water to starting line and you will spin!! can try going around water box and do dry hops to clean tires off. that works with street tires or slicks!!!!
Re: Burnout help [Re: mechanic190] #2078660
05/23/16 04:26 AM
05/23/16 04:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As mentioned, the stock valve body uses the low band apply when shifted into manual low. It only uses the sprag in low gear if you leave the car in Drive.
Manual second gear seems to be a good choice if you have the power to do a second gear burnout.
I think the origin of the no burnout in low, only second gear, was from the instructions from some of the old manual reverse or trans brake valve bodies that may not of had low band apply?
Re: Burnout help [Re: mechanic190] #2078792
05/23/16 01:14 PM
05/23/16 01:14 PM
Wyoming
Wyoming
I am running slicks. Not sure how that rumor got started but I've also heard that low band apply isn't quite enough to save the drum. And I've also heard that The drum won't explode at speeds less than 6000 Rpms which is 12k Rpms for the drum.
