440 over heating.
#2078458
05/22/16 09:31 PM
05/22/16 09:31 PM
Posts: 16 Fredonia, NY
diesel
Fredonia, NY
Hey guys. Hopefully someone might have an idea. I have a 69 stock 440 that over heats if she comes to a stop for any length of time, however she could drive across the country as long as she never had to stop. Things that have been checked,replaced, or installed are: 1. Checked the water pump housing for any restriction, 2. replaced the water pump, 3. a variety of thermostats have been installed even one that had the guts removed so it was just a pass through. 4. a variety of fans, from fixed fans to flex fans, all while having a correct fitting shroud in place, 5. replaced the radiator from a stock, to a 4 core, to now currently an aluminum 4 core. 6. it is timed correctly 7. now have removed the fan and have installed electric fans in a push and pull (correct fitting custom shroud on the pull fan) the pull fan was installed first, still not enough so the push fans were installed. 8. pulleys have been replaced with a march pulley system. 9. have removed the insulation pad from the inside of the hood. Any new ideas would be greatly appreciated! Thanks in advance. I am working doubles over the next couple of days, so if you ask a question and I don't get right back, its not a slight, I'm simply at work with no computer access.
Re: 440 over heating.
[Re: diesel]
#2078467
05/22/16 09:56 PM
05/22/16 09:56 PM
RapidRobert
How hot? & how hot at the stoplight and how hot on the road. confirm with a known good reading gauge. what came to mind is block cooling passages full of crud and a possible combustion leak into the cooling system. tho I would think either of them would make it run hot or at least significantly hotter at speed. On those two if it is one of them: A person can pull the core plugs & blast it out with the car wash wand/an emmissions testing station can set their probe in the air space above the coolant in the radiator & it'll immediately show the presence of hydrocarbons. this is a toughie! keep us posted. At first blush it sure sounds like inadequate air & possibly water flow at slower speeds. is the fan properly positioned into the schroud?
[Re: diesel]
#2078486
05/22/16 10:45 PM
05/22/16 10:45 PM
Posts: 15,469 Omaha Ne
TJP
Omaha Ne
Your symptoms indicate inadequate air flow at low speed, You're dual electric fans maybe be contributing. More info is needed, IE: Radiator size and source, Fan sizing and source. To properly diagnose: Step one: verify actual temps with a thermocouple and quality meter. Step two, report your findings
[Re: diesel]
#2078497
05/22/16 11:01 PM
05/22/16 11:01 PM
Posts: 5,445 So Cal
Sinitro
So Cal
All of ur fixes have been external to the engine... Sounds like ur internal water passages are plugged, and the block/heads needs to be flushed out.. Just my $0.02...
[Re: SportF]
#2078527
05/22/16 11:35 PM
05/22/16 11:35 PM
RapidRobert
I gotta agree with SportF, if it was leaking a slight bit of combustion at idle it for sure would get worse "at speed" & it ain't cuz it is OK "at speed". K.I.S.S. start with how much air is flowing across the rad fins at idle. EDIT what is your pulley ratio?
[Re: diesel]
#2078663
05/23/16 04:39 AM
05/23/16 04:39 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Temp guns are good for telling you temps.
Pure Water: 0 C / 32 F - 100 C / 212 F 50/50 mix of C2H6O2/Water: -37 C / -35 F - 106 C / 223 F
@ 15 psi raises the boiling point another 45 F (25 C) 50/50 + 15 psi rad cap = 131 C / 268 F
Make sure you have a maximum of a 50/50 mix (being in NY, 60/40 would be better). Pure water transfers heat a lot more effectively than C2H6O2. Good airflow through the rad ( a loose leaf paper that stick to the rad with the fan on is a good indication) Good rad cap of at least 15 psi.
^^ those are the basics, now;
Check to see if the water pump pulley is glazed. Belt could slip on it. Oversize W/P pulley? Right diameter pulley?
When it takes more than a sweet mullet to prove you rule at the trailer park..
