rear disc bakes and longer studs #2077733
05/21/16 04:28 PM
05/21/16 04:28 PM
MN
58pwrwgn Offline OP
58pwrwgn  Offline OP
MN
Do the rear disc brake kits require longer studs. The rearend I plan to use needs a number of studs. Maybe in the future I my add rear discs and would prefer to only have to replace them once.
Re: rear disc bakes and longer studs [Re: 58pwrwgn] #2077737
05/21/16 04:34 PM
05/21/16 04:34 PM
AndyF Offline
AndyF  Offline
Shouldn't be an issue. The hat on a rotor is usually about 1/4 inch thick while the drum might be 1/8 thick. You shouldn't notice the difference.
Re: rear disc bakes and longer studs [Re: AndyF] #2077780
05/21/16 06:21 PM
05/21/16 06:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
while not generally a concern with steel wheels adding discs to the rear regarding stud length, it can become an issue with aftermarket aluminum wheels because of the added thickness of the wheel center and some rotor kits can be upward of 3/8" thick in the hat area, so the OP should consider if aluminum wheels are in future plans
Re: rear disc bakes and longer studs [Re: DAYCLONA] #2077950
05/21/16 10:52 PM
05/21/16 10:52 PM
IN
ahy Offline
ahy  Offline
IN
On my rear drum brake setup, OE length studs were just long enough with aluminum wheels with just a bit over 1/2" thread engagement. I didn't like being marginal in that respect so went to 3" studs. When I changed to discs, no problem with the 3" studs. They still "stick out" but that is OK!
