OD 833 thoughts? #2076900
05/20/16 01:38 AM
05/20/16 01:38 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Well after a long delay, I am finally going to start on my 84 D100 truck here within the next month. Its a 318 with a od 833 tranny. I am going to put a stout 360 in it. My question is can the tranny hold up to some spirited driving? By that I mean some drag strip use and a occasional burnout. If I was to put a regular 833 tranny in the truck, could I use the shifter, rods etc.. that I have now? Any help would be appreciated!
Re: OD 833 thoughts? [Re: 360D100] #2076908
05/20/16 01:50 AM
05/20/16 01:50 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Here is a pic of the truck. Nothing special yet.
Re: OD 833 thoughts? [Re: 360D100] #2076909
05/20/16 01:53 AM
05/20/16 01:53 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Another
Re: OD 833 thoughts? [Re: 360D100] #2076911
05/20/16 01:54 AM
05/20/16 01:54 AM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
Yes, I think it will hold up to some fun. I ran one behind my 383 in a roadrunner.
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: OD 833 thoughts? [Re: 360D100] #2076918
05/20/16 02:12 AM
05/20/16 02:12 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yes, don't believe the hype that they won't hold up.
I know a Guy who's been running one in a 511 Six Pak B-body for years and it's still going strong.
I'm beating on two of them at the moment.
And, if you wreck it, $100.00 for another and away you go again.
Best kept secret in the Mopar world, and that truck you have is a bit of a rare animal (OD small block bellhousing up )
Mo' Farts
Moderated by "tbagger".
Re: OD 833 thoughts? [Re: Grizzly] #2076942
05/20/16 03:16 AM
05/20/16 03:16 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
They hold up fine as long as you don't run slicks.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: OD 833 thoughts? [Re: 360D100] #2078222
05/22/16 01:04 PM
05/22/16 01:04 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Ok thanks, I will just run the od. When I swap motors, would it be possible to install the motor and tranny together from the top as one unit?
Re: OD 833 thoughts? [Re: 360D100] #2078276
05/22/16 02:41 PM
05/22/16 02:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes there is plenty of room. You could get one of the harbor freight engine levelers for the engine hoist to make it easier.
Re: OD 833 thoughts? [Re: 360D100] #2079107
05/23/16 11:32 PM
05/23/16 11:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the first and second gear is about as strong as any 4 speed but three and four are weak because their position on the mainshaft is switched---if the bulk of your runs are in 1-2 you are good---be firm at 3 then let off it in 4......
Re: OD 833 thoughts? [Re: 360D100] #2079134
05/24/16 12:22 AM
05/24/16 12:22 AM
AZ
Mike P Offline
Mike P  Offline
AZ
".....Yes, don't believe the hype that they won't hold up......"
I've got a cracked aluminum case from A833 OD transmissions under the bench and have come across a couple of more cracked ones to prove it's not all hype.
That being said I have an iron case A833 OD in my 57 Plymouth that has held up well and I'm not afraid to hammer on.
Just my twocents but if it's aluminum it will probably be on borrowed time, an iron case one should be fine.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: OD 833 thoughts? [Re: 360D100] #2079930
05/25/16 12:05 PM
05/25/16 12:05 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
chevy circle track guys look for 833 that are behind those early 5.7 diesels---they have a cult following because they are stronger than the old muncie---yes the iron case is stronger and is only surpassed by the hemi box....you are good to go....
Re: OD 833 thoughts? [Re: 360D100] #2080108
05/25/16 04:03 PM
05/25/16 04:03 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
What's said above.....I like them....I'm an 833 fan...overdrive or not.
Moparlee
Re: OD 833 thoughts? [Re: 360D100] #2081109
05/27/16 02:53 AM
05/27/16 02:53 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Thanks every one! I do believe mine is the aluminum case unit but I am going to run it. I may pick up a spare just in case. When I pull the motor- may pull the motor and tranny out together not sure yet. What all do I have to disconnect as far as the clutch is concerned? Linkage, z bar etc..? Never have done a 4-speed before. Thanks
Re: OD 833 thoughts? [Re: 360D100] #2081830
05/28/16 01:42 PM
05/28/16 01:42 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Also can I leave the shifter and shifter linkage hooked up? Just remove the shifter handle? Thanks
Re: OD 833 thoughts? [Re: 360D100] #2083391
05/31/16 02:07 PM
05/31/16 02:07 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Don't beat on the aluminum case one - look for a steel case one to beat on. The aluminum case isn't bushed for the countershaft and eventually wallows out the hole in the case for the countershaft and the trans pukes its guts.
