Stealth Heads #2076719
05/19/16 08:12 PM
05/19/16 08:12 PM
B.C. Canada
hankcrank Offline OP
B.C. Canada
The suggested valve spring and retainer upgrade on 440Source site for Stealth heads are CompCam parts. Does anyone know the actual C.C part numbers for parts?
Re: Stealth Heads [Re: hankcrank] #2076793
05/19/16 10:13 PM
05/19/16 10:13 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Comp 10 deg steel retainers #741-16
Locks to suit #611-16
Plus 0.050 locks #614-16
These are what I got for my CNC version Stealths , because of spring supply issues ended up with plus 0.100 titanium retainer and lock set
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Stealth Heads [Re: hankcrank] #2077546
05/21/16 07:15 AM
05/21/16 07:15 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
You can also us the 613 locks. Believe the difference is the 611 are clearanced for lash caps the 613 are not.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
