Spinning wheel stud #207655
01/29/09 12:53 PM
01/29/09 12:53 PM
Texas
68Chrgr Offline OP
68Chrgr  Offline OP
Texas
I have a 68' Charger and I have a wheel stud that is spinning in the drum when I try to remove the lug nut. How can I remove the lug nut to remove the tire? Need Help.
Thanks.
Re: Spinning wheel stud [Re: 68Chrgr] #207656
01/29/09 12:55 PM
01/29/09 12:55 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I had one do that, I used an impact wrench and push it to the side as much as I could enough to get it moving and came right off... it is a pain!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Spinning wheel stud [Re: Silver70] #207657
01/29/09 01:02 PM
01/29/09 01:02 PM
Texas
68Chrgr Offline OP
68Chrgr  Offline OP
Texas
Thanks alot for the input. I will give that a try.
If anyone has anymore ideas or tips I am more than willing to give them a try.
Re: Spinning wheel stud [Re: 68Chrgr] #207658
01/29/09 01:15 PM
01/29/09 01:15 PM
Tulsa, OK
73cudaproject Offline
Tulsa, OK
Thanks.
Several years ago I bought a car which had locking lugs. Must have been from the factory as I recall the key was suppose to have been attached to a cable on the lug wrench but was missing. The guy at the tire store simply put a 4-way on the lug and then jumped on the wrench breaking off the entire stud. You might have to give this a try. Good Luck!
Re: Spinning wheel stud [Re: 68Chrgr] #207659
01/29/09 01:58 PM
01/29/09 01:58 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I don't know what wheels you're running, but if it's on the front and you can get to the center and remove the nut, just pull the whole wheel and drum off together so you can get behind the stud and either weld it to the drum or cut it off.
Jeff Adams 64 426 Polara
