HP with Indy ez325 cnc heads #2076374
05/19/16 10:34 AM
05/19/16 10:34 AM
Middletown, Ohio
Joes66dart Offline OP
Middletown, Ohio
I'm building a new 520 low deck with indy ez325 cnc heads. I'm just wondering what kind of HP numbers guys are getting out of these heads. Here is a little info on my combo just in case anyone is wondering.
400 low deck 4.350 bore
4.375 K1 crank
6.535 BBC K1 rods
Je custom piston with .043 rings gap less top and Napier second. Low tension oil ring
.041 quench right at 13 to 1 comp.
Indy 400-3 intake
1250 pro systems dominator on e85
Comp custom grind .702 lift cam.
Bob weight is right at 2100 grams
We run a vacuum pump.
Re: HP with Indy ez325 cnc heads [Re: Joes66dart] #2076404
05/19/16 11:41 AM
05/19/16 11:41 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
You have correct flow#s on the heads or just what Indy is advertising? Also what is the duration @ .050 on the cam?
Re: HP with Indy ez325 cnc heads [Re: Joes66dart] #2076411
05/19/16 11:50 AM
05/19/16 11:50 AM
Middletown, Ohio
Middletown, Ohio
The heads flowed 375 and 218 @.700. They were flowed at spires speed shop. I'm having some work done on the exhaust port before they get bolted on. They should pick up quite a bit on the exhaust side when they are done. I will have to dig out the cam card for the duration.
Re: HP with Indy ez325 cnc heads [Re: Joes66dart] #2076429
05/19/16 12:24 PM
05/19/16 12:24 PM
SoCal
Brian Hafliger Offline
SoCal
4.375 K1 crank
6.535 BBC K1 rods
Indy 400-3 intake
We've made right at 750HP with a pump gas 540.
http://www.hotrod.com/cars/featured/1405-horsepower-540ci-dodge/
Brian Hafliger
Re: HP with Indy ez325 cnc heads [Re: Joes66dart] #2076435
05/19/16 12:43 PM
05/19/16 12:43 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
13.7-1 CR. 1000 CFM 4150. Indy EZ-1 with a 2.25 intake valve. Flow around 360 @ .600
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: HP with Indy ez325 cnc heads [Re: Joes66dart] #2076442
05/19/16 12:52 PM
05/19/16 12:52 PM
AndyF Online content
AndyF  Online Content
You can get 700, 800 or 900 hp out of those heads. Just depends what parts you put around them.
Your motor sounds like maybe 750 to 800 hp with 13:1 compression and a modest cam. I didn't start to make serious power with my EZ heads until we converted them over to Jesel rocker arms. Once we had the high ratio Jesel arms and we cranked the compression up to 15:1 the engine came alive.
